[Osgeo4w-trac] [osgeo4w] #458: Generate setup.ini based on aribitrary date and/or time
OSGeo4W trac_osgeo4w at osgeo.org
Fri Mar 6 21:08:48 PST 2015
Reporter:  maphew       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Installer
 Version:               |    Keywords:  setup.ini
 I released a new [wiki:pkg-apt] testing package today. When I started
 setting up an environment to test what it will do in an upgrade situation
 I realised I need to put Osgeo4W into an older state, which means
 installing no-longer-current packages first. This isn't so easy.
 I think the easiest approach is likely to be to adapting `osgeo4w-
 regen.sh` and `genini` to generate a setup.ini based on a date stamp. Then
 issuing an instruction like `regen.sh 2014-06-01` would crawl the release
 package tree, ignore any files newer than said date, and generate
 `setup_2014-06-01.ini`.
 I scanned `genini` for likely places to put a date filter, but my perl is
 too weak for the task. ;-)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/458>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
