[Osgeo4w-trac] [osgeo4w] #458: Generate setup.ini based on aribitrary date and/or time
OSGeo4W trac_osgeo4w at osgeo.org
Sat Mar 7 02:28:50 PST 2015
Reporter:  maphew       |        Owner:  osgeo4w-dev@…
    Type:  enhancement  |       Status:  closed
Priority:  major        |    Component:  Installer
 Version:               |   Resolution:  fixed
Keywords:  setup.ini    |
Changes (by jef):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 {{{genini}}} now has a {{{--date=yyyy-mm-dd}}} argument and ignores older
 files.
 {{{regen.sh}}} wasn't updated and you'll have to run genini manually like
 this:
 jef at download:~$ /osgeo/download/osgeo4w/genini --date=2015-03-01
 --arch=x86 --recursive --output=old.ini
 /osgeo/download/osgeo4w/x86/release
 error: /osgeo/download/osgeo4w/x86/release/grass/grass71-dev/setup.hint:7:
 can't open
 /osgeo/download/osgeo4w/x86/release/grass/grass71-dev/grass71-dev-7.1.svn-r64718-1.tar.bz2
 - No such file or directory
 can't open
 error: /osgeo/download/osgeo4w/x86/release/mapserver/mapserver-dev
 /mapscript-java-dev/setup.hint:6: not enough package files in
 /osgeo/download/osgeo4w/x86/release/mapserver/mapserver-dev/mapscript-
 java-dev
 /mapscript-python-dev/setup.hint:6: not enough package files in
 python-dev
 error: /osgeo/download/osgeo4w/x86/release/mapserver/mapserver-stable-dev
 /mapscript-java-stable-dev/setup.hint:6: not enough package files in
 /mapscript-python-stable-dev/setup.hint:6: not enough package files in
 dev/setup.hint:7: not enough package files in
 Note that that produces more entries like the one from #457, because that
 apparently wasn't fixed yet and the nightly builds are cleaned up
 regularly and there are no files left for older states.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/458#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
