[Osgeo4w-trac] [osgeo4w] #529: Add gdal_array to python3-gdal
OSGeo4W trac_osgeo4w at osgeo.org
Fri Apr 21 00:49:44 PDT 2017
Reporter:  hmercier     |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by hmercier):
 Ok, thanks.
 For information, I noticed there is a python3-gdal-dev package here :
 http://download.osgeo.org/osgeo4w/x86_64/release/gdal/gdal-dev/python3
 -gdal-dev/ (without setup.hint so not available through the installer).
 I manually installed it and python3 crashes when doing "from osgeo import
 gdal_array".
 From what I can see, python3-gdal-dev is compiled with MSVC2015 and GDAL
 with MSVC2010, which I guess should be the root of the problem (?). I had
 the same problem on a manual compilation of python3-gdal with MSVC2015.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/529#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
