[Osgeo4w-trac] [osgeo4w] #466: Python stopped working when using python gdal_calc and band.ReadAsArray() on Windows
OSGeo4W trac_osgeo4w at osgeo.org
Mon Apr 24 04:51:01 PDT 2017
on Windows
Reporter:  miro         |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:  gdal python  |
Comment (by rouault):
 The issue can be more simply reproduced when just doing "from osgeo import
 gdalnumeric" and exiting the Python
 console.
 This doesn't look like a fundamental flow of GDAL on Windows, since when
 using miniconda,
 or when building myself GDAL (with VS 2010 express, 64 bit), I don't have
 this issue.
 For the record, my build recipee for the python bindings
 - install Python 2.7.12 64bit
 - pip install numpy ==> install numpy 1.11.2
 - set DISTUTILS_USE_SDK=1
 - set MSSdk=1
 - cd gdal/swig/python
 - python setup.py build
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/466#comment:9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
