[Osgeo4w-trac] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
trac_osgeo4w at osgeo.org
Thu May 5 01:26:02 PDT 2022
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: fixed
Keywords: |
Comment (by jef):
`qgis*.vars` doesn't include `SSL_CERT_FILE`, hence it's not included in
the `.env` and in turn not set, when you start the `.exe` directly (eg. by
using the shortcut). In the shell and QGIS from `qgis*.bat` it should
work.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:13>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
