[Osgeo4w-trac] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
    trac_osgeo4w at osgeo.org
    Thu May  5 01:45:57 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  major        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by hellik):
 Replying to [comment:13 jef]:
 > QGIS from  `qgis*.bat` it should work.
 started here `qgis.bat` in OSGeo4W Ver 2:
 # Python Console
 # Use iface to access QGIS API interface or type help(iface) for more info
 # Security warning: typing commands from an untrusted source can harm your
 computer
 exec(Path('C:/Users/hkmyr/AppData/Local/Temp/tmpxzb_61_i.py').read_text())
 ssl prgcloud.com: FAIL A failure in the SSL library occurred (_ssl.c:1129)
 urllib prgcloud.com: FAIL <urlopen error A failure in the SSL library
 occurred (_ssl.c:1129)>
 ssl www.prgcloud.com: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 urllib www.prgcloud.com: FAIL <urlopen error A failure in the SSL library
 ssl www.python.org: OK
 urllib www.python.org: OK
 ssl grass.osgeo.org: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 urllib grass.osgeo.org: FAIL <urlopen error A failure in the SSL library
 ssl www.osgeo.org: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 urllib www.osgeo.org: FAIL <urlopen error A failure in the SSL library
 still a failure.
 system info
 QGIS version
 3.24.2-Tisler
 QGIS code revision
 13c1a028
 Compiled against Qt
 5.15.2
 Running against Qt
 5.15.3
 Python version
 3.9.5
 Compiled against GDAL/OGR
 3.4.2
 Running against GDAL/OGR
 3.4.3
 PROJ version
 9.0.0
 EPSG Registry database version
 v10.054 (2022-02-13)
 GEOS version
 3.10.2-CAPI-1.16.0
 SQLite version
 3.38.1
 PDAL version
 2.3.0
 PostgreSQL client version
 unknown
 SpatiaLite version
 5.0.1
 QWT version
 6.1.3
 QScintilla2 version
 2.11.5
 OS version
 Windows 10 Version 2009
 Active Python plugins
 kmltools
 3.1.10
 latlontools
 3.5.3
 LocatePoints
 0.3.4
 MultiDistanceBuffer
 3.2.4
 openlayers_plugin
 2.0.0
 OSMDownloader
 1.0.3
 qgisgbifapi
 0.3.2
 QuickOSM
 1.16.0
 quick_map_services
 0.19.11.1
 scriptrunner3
 3.0.5
 SentinelHub
 2.0.0
 vrtbuilderplugin
 0.9.20210222T174536.master
 db_manager
 0.1.20
 grassprovider
 2.12.99
 MetaSearch
 0.3.6
 processing
 2.12.99
 sagaprovider
 2.12.99
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:14>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
