[Osgeo4w-trac] [osgeo4w] #740: More gdal-dev, qgis-dev gremlins reading tiffs
    trac_osgeo4w at osgeo.org
    Mon May  9 04:14:59 PDT 2022
Reporter:  houska1  |      Owner:  osgeo4w-dev@…
    Type:  defect   |     Status:  new
Priority:  major    |  Component:  Package
 Version:           |   Keywords:  gdal qgis dev tiff
 Thanks for fixing LERC (https://trac.osgeo.org/osgeo4w/ticket/739)
 Unfortunately, there's some additional tiff reading issues in qgis-dev
 relying on gdal-dev 3.6.0
 tiffs with the following structure (gdalinfo) that load fine in qgis
 3.24.2 using gdal 3.4.3 now fail to load in dev:
 Image Structure Metadata:
   COMPRESSION=YCbCr JPEG
   INTERLEAVE=PIXEL
   JPEGTABLESMODE=1
   JPEG_QUALITY=75
   SOURCE_COLOR_SPACE=YCbCr
 The qgis error message is:
 2022-05-09T06:20:48     WARNING    201404 DRAPE IR fc (RVCA) :
 C:/...path.../DRAPE 2014 IR compressed.tif, band 3: IReadBlock failed at X
 offset 23, Y offset 30: TIFFReadEncodedTile() failed.
 C:/...path.../DRAPE 2014 IR compressed.tif, band 2: IReadBlock failed at X
 C:/Users/...path.../DRAPE 2014 IR compressed.tif, band 1: IReadBlock
 failed at X offset 23, Y offset 30: TIFFReadEncodedTile() failed.
 I've made the above referenced tiff available at
 https://www.dropbox.com/s/jnu5iwg5ehlll34/DRAPE%202014%20IR%20compressed.tif?dl=0
 until closure of this ticket. Warning 50Mb. Similar failures on other
 similarly encoded tiffs.
 Thanks!
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/740>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
