[Osgeo4w-trac] [osgeo4w] #740: More gdal-dev, qgis-dev gremlins reading tiffs
OSGeo4W trac_osgeo4w at osgeo.org
Mon May 9 04:16:07 PDT 2022
Reporter:  houska1             |       Owner:  osgeo4w-dev@…
    Type:  defect              |      Status:  new
Priority:  major               |   Component:  Package
 Version:                      |  Resolution:
Keywords:  gdal qgis dev tiff  |
Description changed by jef:
Old description:
> Thanks for fixing LERC (https://trac.osgeo.org/osgeo4w/ticket/739)
> Unfortunately, there's some additional tiff reading issues in qgis-dev
> relying on gdal-dev 3.6.0
> tiffs with the following structure (gdalinfo) that load fine in qgis
> 3.24.2 using gdal 3.4.3 now fail to load in dev:
> Image Structure Metadata:
>   COMPRESSION=YCbCr JPEG
>   INTERLEAVE=PIXEL
>   JPEGTABLESMODE=1
>   JPEG_QUALITY=75
>   SOURCE_COLOR_SPACE=YCbCr
> The qgis error message is:
> 2022-05-09T06:20:48     WARNING    201404 DRAPE IR fc (RVCA) :
> C:/...path.../DRAPE 2014 IR compressed.tif, band 3: IReadBlock failed at
> X offset 23, Y offset 30: TIFFReadEncodedTile() failed.
> C:/...path.../DRAPE 2014 IR compressed.tif, band 2: IReadBlock failed at
> C:/Users/...path.../DRAPE 2014 IR compressed.tif, band 1: IReadBlock
> failed at X offset 23, Y offset 30: TIFFReadEncodedTile() failed.
> I've made the above referenced tiff available at
> https://www.dropbox.com/s/jnu5iwg5ehlll34/DRAPE%202014%20IR%20compressed.tif?dl=0
> until closure of this ticket. Warning 50Mb. Similar failures on other
> similarly encoded tiffs.
> Thanks!
New description:
 Thanks for fixing LERC (#739)
   INTERLEAVE=PIXEL
   JPEGTABLESMODE=1
   JPEG_QUALITY=75
 C:/...path.../DRAPE 2014 IR compressed.tif, band 3: IReadBlock failed at X
 C:/...path.../DRAPE 2014 IR compressed.tif, band 2: IReadBlock failed at X
 Thanks!
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/740#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
