[Osgeo4w-trac] [osgeo4w] #847: qgis-dev installs and uses both gdal-dev310.dll and gdal309.dll
    trac_osgeo4w at osgeo.org
    Fri Aug 23 04:31:44 PDT 2024
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  normal       |  Component:  Package
 Version:               |   Keywords:
 qgis-dev-800-f90a7c04b1-1 installs and use both gdal-dev
 (3.10.0-603-b39ca5a8b5-1), gdal-dev310-runtime (3.10.0-603-b39ca5a8b5-1)
 and gdal309-runtime (3.9.2-1)
 I think it would be better to make qgis-dev only use gdal-dev.
         The GDAL/OGR 3.9 runtime library
         Required by: pdal-libs
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/847>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
