[Osgeo4w-trac] [osgeo4w] #845: Add GUI language selection to Setup GUI (was: Add GUI language selection to osgeo4w-setup.exe)
    trac_osgeo4w at osgeo.org
    Fri Aug 23 07:10:02 PDT 2024
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  reopened
Priority:  normal       |   Component:  Installer
 Version:               |  Resolution:
Keywords:               |
Changes (by andreaerdna):
 * status:  closed => reopened
 * resolution:  invalid =>
 * summary:  Add GUI language selection to osgeo4w-setup.exe => Add GUI
Old description:
> The new version of osgeo4w-setup.exe uses translated string based on the
> system language.
> IT would be useful if it was possible to select the preferred language in
> the GUI other then the system language (i.e. the English language).
New description:
 Since OSGeo4W Setup GUI uses translated string based on the system
 language, I think it would be useful if it was possible to select the
 preferred language directly in the GUI with a drop-down list overriding
 then the system language (i.e. the English language instead of the Italian
 language on an Italian system).
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/845#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
