[Osgeo4w-trac] [osgeo4w] #896: SAGA: Function GDALRegister ... did not register a driver ... (it needs to be built against GDAL 3.12)
OSGeo4W trac_osgeo4w at osgeo.org
Fri Dec 12 18:27:38 PST 2025
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  normal       |  Component:  Package
 Version:               |   Keywords:
 Running QGIS LTR 3.40.13 (QGIS-OSGeo4W-3.40.13-1.msi) on Windows 10, when
 a SAGA-GIS processing algorithm (provided by the "Processing Saga NextGen
 Provider" plugin) involving the SAGA command io_gdal (e.g. "Basic Terrain
 Analysis") is executed, then the following error messages are printed in
 the processing algorithm's log:
 ERROR 1: Function GDALRegister_ECW_JP2ECW of
 C:\PROGRA~1\QGIS34~1.13\apps\gdal\lib\gdalplugins\gdal_ECW_JP2ECW.dll did
 not register a driver ECW
 not register a driver JP2ECW
 ERROR 1: Function GDALRegister_MrSID of
 C:\PROGRA~1\QGIS34~1.13\apps\gdal\lib\gdalplugins\gdal_MrSID.dll did not
 register a driver MrSID
 register a driver JP2MrSID
 ERROR 1: Function GDALRegister_HDF5 of
 C:\PROGRA~1\QGIS34~1.13\apps\gdal\lib\gdalplugins\gdal_HDF5.dll did not
 register a driver BAG
 register a driver S102
 register a driver S104
 register a driver S111
 register a driver HDF5
 register a driver HDF5Image
 ERROR 1: Function GDALRegister_GEOR of
 C:\PROGRA~1\QGIS34~1.13\apps\gdal\lib\gdalplugins\gdal_GEOR.dll did not
 register a driver GeoRaster
 ERROR 1: Function RegisterOGRMSSQLSpatial of
 C:\PROGRA~1\QGIS34~1.13\apps\gdal\lib\gdalplugins\ogr_MSSQLSpatial.dll did
 not register a driver MSSQLSpatial
 ERROR 1: Function RegisterOGROCI of
 C:\PROGRA~1\QGIS34~1.13\apps\gdal\lib\gdalplugins\ogr_OCI.dll did not
 register a driver OCI
 ERROR 1: Function RegisterOGRSOSI of
 C:\PROGRA~1\QGIS34~1.13\apps\gdal\lib\gdalplugins\ogr_SOSI.dll did not
 register a driver SOSI
 [Error] Dataset creation failed: Function RegisterOGRSOSI of
 Such errors are probably due to the fact that while QGIS is build against
 GDAL 3.12 and the GDAL plugins installed in
 {{{apps\gdal\lib\gdalplugins}}} are also built against GDAL 3.12,
 io_gdal.dll is built against GDAL 3.11 and thus it fails to correctly load
 the GDAL plugins built against GDAL 3.12.
 This also prevents SAGA-GIS to correctly import and use various raster
 formats.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/896>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
