[Osgeo4w-trac] [osgeo4w] #896: SAGA: Function GDALRegister ... did not register a driver ... (it needs to be built against GDAL 3.12)
OSGeo4W trac_osgeo4w at osgeo.org
Fri Dec 19 02:26:30 PST 2025
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 Fixed in saga 9.10.2-1 (built against GDAL 3.12) for qgis and qgis-ltr.
 Anyway the latest available stand-alone .msi installers for QGIS 3.44.5
 and QGIS LTR 3.40.13 still ship the affected version.
 The issue still occurs using qgis-dev or qgis-qt6-dev, since qgis-dev is
 built against GDAL 3.13 while io_gdal.dll is linked to gdal312.dll but it
 probably tries to use GDAL plugin built against GDAL 3.13.
 [Error] Dataset creation failed: Function GDALRegister_MrSID of
 C:\OSE37B~1\apps\gdal-dev\lib\gdalplugins\gdal_MrSID.dll did not register
 a driver JP2MrSID
 failed: could not find a suitable import driver
 a driver MrSID
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/896#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
