[Osgeo4w-trac] [osgeo4w] #871: Uninstalling Python modules doesn't completely removes all related folders and files
OSGeo4W trac_osgeo4w at osgeo.org
Mon Feb 24 07:50:37 PST 2025
and files
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  normal       |  Component:  Installer
 Version:               |   Keywords:
 As an example, after installing, using and then uninstalling the module
 python3-arrow, the {{{pyarrow}}} folder (containing a __pycache__ folder
 with various .pyc files) is still present in the
 {{{apps\Python312\Lib\site-packages}}} directory.
 Since the {{{pyarrow}}} folder is not deleted, even if the pyarrow module
 was uninstalled, the import of the pyarrow module doesn't fail, as it
 should be instead.
 Also previously reported https://trac.osgeo.org/osgeo4w/ticket/861.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/871>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
