[Osgeo4w-trac] [osgeo4w] #871: Uninstalling Python modules doesn't completely removes all related folders and files
trac_osgeo4w at osgeo.org
Mon Feb 24 07:59:26 PST 2025
and files
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Installer
Version: | Resolution:
Keywords: |
Description changed by jef:
Old description:
> As an example, after installing, using and then uninstalling the module
> python3-arrow, the {{{pyarrow}}} folder (containing a __pycache__ folder
> with various .pyc files) is still present in the
> {{{apps\Python312\Lib\site-packages}}} directory.
> Since the {{{pyarrow}}} folder is not deleted, even if the pyarrow module
> was uninstalled, the import of the pyarrow module doesn't fail, as it
> should be instead.
> Also previously reported https://trac.osgeo.org/osgeo4w/ticket/861.
New description:
should be instead.
Also previously reported #861.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/871#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
