[Osgeo4w-trac] [osgeo4w] #926: error: 12057 when installing OSGEO4W
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jun 16 09:42:13 PDT 2026
Reporter:  ThierryL  |      Owner:  osgeo4w-dev@…
    Type:  defect    |     Status:  new
Priority:  normal    |  Component:  Installer
 Version:            |   Keywords:
 Either through GUI or Command line (osgeo4w-setup.exe -q -k -r -A -s
 https://download.osgeo.org/osgeo4w/v2/ -P proj).
 Would not show mirror sites. Would not download. Finally found log that
 showed that error 1205 appeared for every request.
 Resolved on my PC (Windows 11 Pro build 10.0.2620) by
 temporarily unchecking
 Internet Options -> Advanced -> Security
  _ Check for Publisher's certificate revocation
  _ Check for server certificate revocation
  _ Check for signatures on downloaded programs
  _ Warn about certificate address mismatch
 Did not investigate further.
 Once working, these are the first few output lines from this command:
 D:\Downloads>osgeo4w-setup.exe -q -k -r -A -s
 D:\Downloads>Starting OSGeo4W install, version 2.579
 using locales .1252
 Current Directory: C:\Users\thier\AppData\Local\Temp
 Root Directory: C:\OSGeo4W
 Could not open service McShield for query, start and stop. McAfee may not
 be installed, or we don't have access.
 root: C:\OSGeo4W
 Selected local directory: C:\Users\thier\AppData\Local\Temp
 Menu name: OSGeo4W
 net: Direct
 Loaded cached mirror list
 get_url_to_membuf https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
 getUrlToStream https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
 User-Agent: default is "OSGeo4W-Setup/2.579 (Windows NT
 6.2.9200;Win64;0409)"
 Request for URL https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
 satisfied from cache
 site: https://download.osgeo.org/osgeo4w/v2/
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/926>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
