[Osgeo4w-trac] [osgeo4w] #926: error: 12057 when installing OSGEO4W
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jun 16 09:43:10 PDT 2026
Reporter:  ThierryL  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  normal    |   Component:  Installer
 Version:            |  Resolution:
Keywords:            |
Description changed by ThierryL:
Old description:
> Either through GUI or Command line (osgeo4w-setup.exe -q -k -r -A -s
> https://download.osgeo.org/osgeo4w/v2/ -P proj).
> Would not show mirror sites. Would not download. Finally found log that
> showed that error 1205 appeared for every request.
> Resolved on my PC (Windows 11 Pro build 10.0.2620) by
> temporarily unchecking
> Internet Options -> Advanced -> Security
>  _ Check for Publisher's certificate revocation
>  _ Check for server certificate revocation
>  _ Check for signatures on downloaded programs
>  _ Warn about certificate address mismatch
> Did not investigate further.
> Once working, these are the first few output lines from this command:
> D:\Downloads>osgeo4w-setup.exe -q -k -r -A -s
> D:\Downloads>Starting OSGeo4W install, version 2.579
> using locales .1252
> Current Directory: C:\Users\thier\AppData\Local\Temp
> Root Directory: C:\OSGeo4W
> Could not open service McShield for query, start and stop. McAfee may not
> be installed, or we don't have access.
> root: C:\OSGeo4W
> Selected local directory: C:\Users\thier\AppData\Local\Temp
> Menu name: OSGeo4W
> net: Direct
> Loaded cached mirror list
> get_url_to_membuf https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
> getUrlToStream https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
> User-Agent: default is "OSGeo4W-Setup/2.579 (Windows NT
> 6.2.9200;Win64;0409)"
> Request for URL https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
> satisfied from cache
> site: https://download.osgeo.org/osgeo4w/v2/
New description:
 showed that error 12057 appeared for every request.
 using locales .1252
 root: C:\OSGeo4W
 Menu name: OSGeo4W
 net: Direct
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/926#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
