[Oskari-user] Installing Oskari Map Application using EPSG:3067 as a default coordinate system
Keijo Kangas
keijo.kangas at kuntotekniikka.fi
Thu Aug 2 01:23:02 PDT 2018
Hello,
I am installing Oskari Map Application using pre-installed environment with
these instructions: http://oskari.org/documentation/backend/setup-jetty
However, I want to set default coordinate system to EPSG:3067 and set it to
oskari-ext.properties before starting the start.jar (java -jar start.jar)
but when I log in to pre-installed Geoserver I can see that the Native SRS
is EPSG:4326. How can I set the default coordinate system to EPSG:3067 so
that Oskari Map installation process creates oskaridb database tables and
geoserver Layers compatible to EPSG:3067 coordinate system? Thank you for
your help!
Keijo Kangas
+358 40 480 9035
Software developer
<http://www.kuntotekniikka.fi/> www.kuntotekniikka.fi
<http://www.facebook.com/kuntotekniikka> www.facebook.com/kuntotekniikka
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180802/43a90eea/attachment.html>
More information about the Oskari-user
