[Oskari-user] Installing Oskari Map Application using EPSG:3067 as a default coordinate system
Sanna Jokela
sanna at gispo.fi
Sun Aug 5 21:55:22 PDT 2018
Good morning!
Has Sami some ideas on this? I have been on on vacation, so sorry for the
delay in answering. I have also heard some similar problems with
projections in another case, so it would be great to document this better.
Br,
Sanna
On 2 August 2018 at 11:23, Keijo Kangas <keijo.kangas at kuntotekniikka.fi>
wrote:
> Hello,
> I am installing Oskari Map Application using pre-installed environment
> with these instructions: http://oskari.org/documentation/backend/setup-
> jetty
> However, I want to set default coordinate system to EPSG:3067 and set it
> to oskari-ext.properties before starting the start.jar (java -jar
> start.jar) but when I log in to pre-installed Geoserver I can see that the
> Native SRS is EPSG:4326. How can I set the default coordinate system to
> EPSG:3067 so that Oskari Map installation process creates oskaridb database
> tables and geoserver Layers compatible to EPSG:3067 coordinate system?
> Thank you for your help!
> Keijo Kangas
> +358 40 480 9035
> Software developer
> www.kuntotekniikka.fi
> www.facebook.com/kuntotekniikka
> Oskari-user mailing list
> Oskari-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/oskari-user
Sanna Jokela
paikkatietoasiantuntija
Gispo Oy
0407664607
www.gispo.fi
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180806/2c725250/attachment.html>
More information about the Oskari-user
