[Oskari-user] Oskari release 1.47.0
Mäkinen Sami (MML)
sami.makinen at maanmittauslaitos.fi
Thu Jun 21 05:57:31 PDT 2018
Hi all,
Oskari version 1.47.0 is now available in GitHub, oskari.org download and the Maven repository. Here's the list of changes: https://github.com/oskariorg/oskari-server/blob/master/ReleaseNotes.md and https://github.com/oskariorg/oskari-frontend/blob/master/ReleaseNotes.md
Frontend
For a full list of changes see: https://github.com/oskariorg/oskari-frontend/milestone/9?closed=1
* Statistical maps now allow for filtering listings based on regionsets and adding more than one indicator at a time
* Users can now use and save custom indicators for statistical maps
* Fixes for statistical maps UI in geoportal
* Layer filters in layer selector are now hidden when selecting the filter would result in empty layer listing
* Geoportal map style is now properly reset after exiting publisher functionality (previously always reset to default style)
* More plugins now support styling in publisher functionality
* Timeseries functionality can now be included in embedded maps (when there's a layer providing timeseries data)
* Publisher can now be opened automatically on startup (Usability improvement when having embedded maps in multiple projections)
* Checking "Don't show this again" in guided tour now works again
* Bugfixes on publisher, hierarchical layerselector and feature data table
Server
For a full list of changes see: https://github.com/oskariorg/oskari-server/milestone/8?closed=1
* Migration from OpenLayers 2 to OpenLayers 4 (see MigrationGuide.md)
* Improvements to userlayer/imported datasets handling
* Statistical maps PXWeb adapter improvements
* Statistical datasource/indicator listings now include regionset and time-variable metadata where available
* Statistical maps error handling improvements
* Layer order modification in hierarchical layers have been fixed
* GetAppSetup can now include common urls as environmental metadata (like login/register) configured in oskari-ext.properties
* Maplayer capabilities caching improvements
* Added Admin route for flushing caches (/action?action_route=Cache&name=[cache name])
* Domain check for published maps is now case-insensitive
* Added server functionalities for handling user generated statistical indicators
* Print functionality now handles layers that require credentials properly
* Saving a view/state of the geoportal now uses the current view as base instead of the system default (Fixes an issue with projection support and saving views)
* Timeseries control can now be included in embedded maps
* Added a concept of "internal layers" that are part of oskari_maplayer table, but are not intended for public view (like baselayers for my places etc)
* Clean up deprecated code
Happy midsummer,
Sami
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180621/fc1667ee/attachment.html>
More information about the Oskari-user
