[Oskari-user] Oskari release 1.47.0
Mäkinen Sami (MML)
sami.makinen at maanmittauslaitos.fi
Mon Jun 25 00:40:20 PDT 2018
Yep, the latest released version is always available at http://demo.oskari.org. Unfortunately the provider for statistical data made an unannounced change to their API (completely removed the dataset and made another dataset available on another URL) which broke the integration. I’ll need to reconfigure the statistical datasource and hope to have time to do it this week. Demo.oskari.org has the default users for Oskari instance so you can log in with user/user. Note that the database can be reset at any time without prior warning so it’s just for testing.
If there’s a public WMS-layer with time dimension available that you would like to try out you can use the admin tools to add it. I’ll leave a little homework for figuring out the admin credentials, but it’s mentioned on this page http://oskari.org/documentation/backend/setup-jetty
Thanks for letting me know about the issue with the User Guide. Currently there’s no user registration available on demo.oskari.org so I’ll remove the link from the User Guide
BR,
Sami
Lähettäjä: Sanna Jokela [mailto:sanna at gispo.fi]
Lähetetty: 25. kesäkuuta 2018 9:28
Vastaanottaja: Mäkinen Sami (MML) <sami.makinen at maanmittauslaitos.fi>
Kopio: oskari-user at lists.osgeo.org
Aihe: Re: [Oskari-user] Oskari release 1.47.0
Thank you Sami for the new release! I'll tweet about it soon :)
Is the release always available straight away also in http://demo.oskari.org/ ?
If so, would it be possible there to have also some demo statistical data (there is the municipalities data but it does not show any indicators) and also time series data for people to test? Then these fixes could be more easily checked.
And is it possible in demo.oskari.org<http://demo.oskari.org> to sign in? If so what is the username & password? It would help a lot in testing the software and see the potential. I noticed that in the demo-site in the User Guide there is no text in "Registering, user information and password", is it just missing?
And great to see Oskari development going fast!
Br,
Sanna Jokela
paikkatietoasiantuntija
Gispo Oy
0407664607
www.gispo.fi<http://www.gispo.fi/>
On 21 June 2018 at 15:57, Mäkinen Sami (MML) <sami.makinen at maanmittauslaitos.fi<mailto:sami.makinen at maanmittauslaitos.fi>> wrote:
Hi all,
Oskari version 1.47.0 is now available in GitHub, oskari.org<http://oskari.org> download and the Maven repository. Here’s the list of changes: https://github.com/oskariorg/oskari-server/blob/master/ReleaseNotes.md and https://github.com/oskariorg/oskari-frontend/blob/master/ReleaseNotes.md
Frontend
For a full list of changes see: https://github.com/oskariorg/oskari-frontend/milestone/9?closed=1
* Statistical maps now allow for filtering listings based on regionsets and adding more than one indicator at a time
* Users can now use and save custom indicators for statistical maps
* Fixes for statistical maps UI in geoportal
* Layer filters in layer selector are now hidden when selecting the filter would result in empty layer listing
* Geoportal map style is now properly reset after exiting publisher functionality (previously always reset to default style)
* More plugins now support styling in publisher functionality
* Timeseries functionality can now be included in embedded maps (when there's a layer providing timeseries data)
* Publisher can now be opened automatically on startup (Usability improvement when having embedded maps in multiple projections)
* Checking "Don't show this again" in guided tour now works again
* Bugfixes on publisher, hierarchical layerselector and feature data table
Server
For a full list of changes see: https://github.com/oskariorg/oskari-server/milestone/8?closed=1
* Migration from OpenLayers 2 to OpenLayers 4 (see MigrationGuide.md)
* Improvements to userlayer/imported datasets handling
* Statistical maps PXWeb adapter improvements
* Statistical datasource/indicator listings now include regionset and time-variable metadata where available
* Statistical maps error handling improvements
* Layer order modification in hierarchical layers have been fixed
* GetAppSetup can now include common urls as environmental metadata (like login/register) configured in oskari-ext.properties
* Maplayer capabilities caching improvements
* Added Admin route for flushing caches (/action?action_route=Cache&name=[cache name])
* Domain check for published maps is now case-insensitive
* Added server functionalities for handling user generated statistical indicators
* Print functionality now handles layers that require credentials properly
* Saving a view/state of the geoportal now uses the current view as base instead of the system default (Fixes an issue with projection support and saving views)
* Timeseries control can now be included in embedded maps
* Added a concept of "internal layers" that are part of oskari_maplayer table, but are not intended for public view (like baselayers for my places etc)
* Clean up deprecated code
Happy midsummer,
Sami
Oskari-user mailing list
Oskari-user at lists.osgeo.org<mailto:Oskari-user at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/oskari-user
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180625/737540b5/attachment-0001.html>
More information about the Oskari-user
