[Oskari-user] Image & URL detection in Myplaceimport?
Sanna Jokela
sanna at gispo.fi
Tue Mar 20 01:05:05 PDT 2018
Hi!
Thanks for the answer! I'm talking about the GFI popup at this case. I'll
submit the issue - maybe we could get some small funding on this -
shouldn't be a big issue :)
Br,
Sanna
On 19 March 2018 at 17:13, Mäkinen Sami (MML) <
sami.makinen at maanmittauslaitos.fi> wrote:
> Hi!
> There’s an existing roadmap item for combining myplaces and userlayer
> functionality: https://github.com/oskariorg/oskari-docs/issues/31 so
> there has been some plans on combining the two and probably analysis will
> follow the same route. Just lacking contributions for making it happen :)
> There has been some development on enabling style edits on userlayers here
> at NLS Finland, but it hasn’t been submitted yet. Can’t say for sure that
> it will be part of the next release (the target date for 1.46.0 is 6th of
> April at the moment).
> For detecting content for making links and embedding images are you
> talking about the featuredata table or the GFI popup or both or something
> else? I guess the GFI popup could do some smart content recognition. Some
> people argue that they want to copy the contents which would not work very
> well for images, but from my perspective it would be a nice change all the
> same. There’s also some talk about improving the import functionality so
> the user could select which fields to import and to re-label them. This
> would be a convenient place for the user to mark which fields should be
> treated as links/images/video etc. Sadly so far it has been only talk and
> no contributions. You should submit this as an issue in GitHub if possible.
> I’ll label it as an enhancement for the frontend. That makes it easier for
> someone to find this request and contribute the change.
> Best regards,
> Sami
> *Lähettäjä:* Oskari-user [mailto:oskari-user-bounces at lists.osgeo.org] *Puolesta
> *Sanna Jokela
> *Lähetetty:* 19. maaliskuuta 2018 10:40
> *Vastaanottaja:* oskari-user at lists.osgeo.org
> *Kopio:* sinikka.paulin at aurajoki.net
> *Aihe:* [Oskari-user] Image & URL detection in Myplaceimport?
> Hello all!
> Is it possible to have URLs detected automatically in Oskari
> Myplaceimport-tool? Tried this with Paikkatietoikkuna and URL-links are
> just plain text.
> This enhancement would give more usability to Myplaceimport feature, if
> one could add attributes with links and also if link ends with image-format
> (.jpg, .png) the pop-up info would show those.
> Also Myplace & Myplaceimport tools could be joined together. Now you can
> not change e.g. the visualisations for datasets but you can change and
> modify Myplace information.
> This was noted when testing the data import with Aurajokisäätiö.
> Best regards,
> Sanna Jokela
> paikkatietoasiantuntija
> Gispo Oy
> 0407664607
> www.gispo.fi
Sanna Jokela
Gispo Oy
0407664607
www.gispo.fi
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180320/bcc79c9e/attachment.html>
More information about the Oskari-user
