[Oskari-user] Bug in Suomi.fi maps - embedded maps?
Sanna Jokela sanna at gispo.fi
Fri Oct 26 01:57:30 PDT 2018
Apparently the clusters are usually multiple points at the same location.
Nothing has changed since I asked. One problem location in Espoo. Image
attached.
[image: screencapture-kela-fi-palvelupisteen-haku-2018-10-26-09_23_08.png]
One thing that I found out from this was, that the data is originally in
json format and brought somehow to the Suomi.fi maps as only one layer.
Similar issues were once in Paikkatietoikkuna when there were landuse plans
containing group layers and the info-tool could drill into just to the
first layer described in the WMS (now I can't test this since the info-tool
does not work at all from the regional landuse plans... probably due to the
source definitions). So could this be a issue more about how the layers are
described in the interface and in which order? Can Oskari GetFeatureInfo
drill into multiple layers from one interface?
Br,
Sanna
On Fri, 26 Oct 2018 at 11:20, Mäkinen Sami (MML) <
sami.makinen at maanmittauslaitos.fi> wrote:
> Hi,
> I don't know if this was changed between the message and now, but looks
> like the points are clustered and clicking a cluster zooms in. So on a
> quick test I couldn't reproduce the problem.
>           Sami
> *Lähettäjä:* Oskari-user <oskari-user-bounces at lists.osgeo.org> käyttäjän
> puolestaSanna Jokela <sanna at gispo.fi>
> *Lähetetty:* 25. lokakuuta 2018 17:52
> *Vastaanottaja:* oskari-user at lists.osgeo.org
> *Aihe:* [Oskari-user] Bug in Suomi.fi maps - embedded maps?
> Hi!
> Asking for a new friend :)
> Suomi.fi maps has a possibility to create embedded maps and with Oskari
> API you can request different things from e.g. your own datasources.
> Is is due to the data source or the embedded maps or the website that the
> info-pop-up shows only one result in those cases when there are multiple
> points on top of each other?
> Example here: https://www.kela.fi/palvelupisteen-haku ==> zoom out to see
> objects with multiple points on top of each other (number is shown in the
> vicinity of the symbol) and click on the symbol ==> only one result is
> shown. Apparently it is also the one that is the lowest.
> In this case the data is requested through API received from the Service
> database in Finland.
> If someone has time to check this at some point, it would be great! At
> least to know which service to blame :)
> BR,
> Sanna Jokela
> GIS specialist / Oskari communication coordinator
> Gispo Ltd
> +358 407664607
> www.gispo.fi
> https://community.oskari.org
Sanna Jokela
Gispo Ltd
+358 407664607
www.gispo.fi
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20181026/c860a7fa/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20181026/c860a7fa/attachment-0001.png>
More information about the Oskari-user mailing list
