[Oskari-user] Bug in Suomi.fi maps - embedded maps?
Mäkinen Sami (MML) sami.makinen at maanmittauslaitos.fi
Fri Oct 26 01:20:29 PDT 2018
I don't know if this was changed between the message and now, but looks like the points are clustered and clicking a cluster zooms in. So on a quick test I couldn't reproduce the problem.
          Sami
Lähettäjä: Oskari-user <oskari-user-bounces at lists.osgeo.org> käyttäjän puolestaSanna Jokela <sanna at gispo.fi>
Lähetetty: 25. lokakuuta 2018 17:52
Vastaanottaja: oskari-user at lists.osgeo.org
Aihe: [Oskari-user] Bug in Suomi.fi maps - embedded maps?
Hi!
Asking for a new friend :)
Suomi.fi maps has a possibility to create embedded maps and with Oskari API you can request different things from e.g. your own datasources.
Is is due to the data source or the embedded maps or the website that the info-pop-up shows only one result in those cases when there are multiple points on top of each other?
Example here: https://www.kela.fi/palvelupisteen-haku ==> zoom out to see objects with multiple points on top of each other (number is shown in the vicinity of the symbol) and click on the symbol ==> only one result is shown. Apparently it is also the one that is the lowest.
In this case the data is requested through API received from the Service database in Finland.
If someone has time to check this at some point, it would be great! At least to know which service to blame :)
BR,
Sanna Jokela
GIS specialist / Oskari communication coordinator
Gispo Ltd
+358 407664607
www.gispo.fi<http://www.gispo.fi/>
https://community.oskari.org
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20181026/45f89b55/attachment.html>
More information about the Oskari-user mailing list
