[Ottawa_users] Map Labelling
Jeff McKenna
jmckenna at dmsolutions.ca
Fri Jun 22 09:07:16 EDT 2007
Howdy Chris,
It's just ANGLE FOLLOW within the LABEL object. It was added in the
4.10 release. It doesn't seem to be perfect (on a single map image at
the street-level some labels will follow the line feature, but some
others for some reason run perpendicular to the feature)...so give it a
try and see if you like it.
jeff
Christopher Thorne wrote:
> Hello Jeff,
> You got me existed when you said "spline text". I can't help but ask how
> is spline text represented in a mapfile then? you would not happen to
> have an example? and what version of mapserver is it in? 10.2 or dev?
> And How good is it? :)
> Chris
> Jeff McKenna wrote:
>> I know we've been looking at the MapText stuff for years and drooling...
>> Note: MapServer now has spline text (labels follow features), I
>> believe through a hack in the GD code.
>> jeff
>> Sampson, David wrote:
>>> Hey Folks,
>>> I'm looking for open source tools that can label maps dynamically.
>>> Examples of proprietary tools would be label EZ by Map Plex
>>> (_http://www.maptext.com/_)
>>> 1. the labels should have conflict detection to eliminate or minimize
>>> over laps.
>>> 2. The labels need to follow features like rivers, road or contour lines
>>> Any sugestions?
>>> The only thing I found was this one:
>>> _http://www.ads.tuwien.ac.at/research/labeling/_
>>> Cheers
More information about the Ottawa_users
