[Ottawa_users] Clipping shapefiles with ogr2ogr
Alyre Chiasson
alyrechiasson at yahoo.ca
Mon Feb 18 14:42:31 EST 2008
Hello,
I suspected that something like below was happening, although the documentation I read regarding the -spat option presents it as a clipping function. I was surprised by the result. I am new to all of this and have no computer science background so I am not familar with a "bbox" . Although I know Python is a flexible multi platform language (I see a lot of references in the Linux world), attempting to learn the language to write a script to do this job or to understand someone else's script I believe would be beyond my time constraints for the current project. I did try to import both shape files into GRASS as layers and then tried to overlay (v.overlay) them but got error messages which I couldn't understand but were basically complaining about missing attributes. Not sure what attributes it was referring to. Is there actually no way to do this within GRASS or QGIS that retains the feature of the shapefile (everthing within the clipping region) without
having to learn a programming language? Would seem to be a desirable function. Not adverse to learning a program language but it would be a much longer term goal.
Thanks
Alyre
----- Original Message ----
From: Tyler Mitchell (OSGeo) <tmitchell at osgeo.org>
To: Ottawa (Canada) Local Chapter List <ottawa_users at lists.osgeo.org>
Sent: Monday, February 18, 2008 12:26:36 PM
Subject: Re: [Ottawa_users] Clipping shapefiles with ogr2ogr
On 18-Feb-08, at 6:22 AM, Paul Spencer wrote:
> My first guess is that ogr2ogr doesn't clip, it uses the bbox as a
> spatial selection and keeps anything that intersects with the
> bbox. Would this account for your results?
That's right, it cannot clip, but will select/return all features
that fit in the area. You can't use ogr2ogr for clipping but I
believe you could write a Python script that calls the OGR and GEOS
functions to do this job.
Tyler
Ottawa_users mailing list
Ottawa_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/ottawa_users
Connect with friends from any web browser - no download required. Try the new Yahoo! Canada Messenger for the Web BETA at http://ca.messenger.yahoo.com/webmessengerpromo.php
URL: http://lists.osgeo.org/pipermail/ottawa_users/attachments/20080218/952e49e9/attachment.html
More information about the Ottawa_users
