[Ottawa_users] Clipping shapefiles with ogr2ogr
Christy Nieman
cnieman at connect.carleton.ca
Mon Feb 18 15:23:24 EST 2008
I just spent a while working on clipping in QGIS/GRASS, and it is quite
simple. I used the GRASS Tools plugin for QGIS to load my shapefiles
into a GRASS mapset. I then converted my mapset's region to a GRASS
vector layer to use as the overlay layer in the clip (v.in.region -
under Vector/Create standard vectors in the QGIS GRASS tools dialog).
Then I used the v.overlay intersection tool to do the clip. This has to
be done one layer at a time.
If you need more details I can provide a specific example.
Christy
Alyre Chiasson wrote:
> Hello,
> I suspected that something like below was happening, although the
> documentation I read regarding the -spat option presents it as a
> clipping function. I was surprised by the result. I am new to all of
> this and have no computer science background so I am not familar with
> a "bbox" . Although I know Python is a flexible multi platform
> language (I see a lot of references in the Linux world), attempting to
> learn the language to write a script to do this job or to understand
> someone else's script I believe would be beyond my time constraints
> for the current project. I did try to import both shape files into
> GRASS as layers and then tried to overlay (v.overlay) them but got
> error messages which I couldn't understand but were basically
> complaining about missing attributes. Not sure what attributes it was
> referring to. Is there actually no way to do this within GRASS or QGIS
> that retains the feature of the shapefile (everthing within the
> clipping region) without having to learn a programming language? Would
> seem to be a desirable function. Not adverse to learning a program
> language but it would be a much longer term goal.
> Thanks
> Alyre
> ----- Original Message ----
> From: Tyler Mitchell (OSGeo) <tmitchell at osgeo.org>
> To: Ottawa (Canada) Local Chapter List <ottawa_users at lists.osgeo.org>
> Sent: Monday, February 18, 2008 12:26:36 PM
> Subject: Re: [Ottawa_users] Clipping shapefiles with ogr2ogr
> On 18-Feb-08, at 6:22 AM, Paul Spencer wrote:
> > My first guess is that ogr2ogr doesn't clip, it uses the bbox as a
> > spatial selection and keeps anything that intersects with the
> > bbox. Would this account for your results?
> That's right, it cannot clip, but will select/return all features
> that fit in the area. You can't use ogr2ogr for clipping but I
> believe you could write a Python script that calls the OGR and GEOS
> functions to do this job.
> Tyler
> Ottawa_users mailing list
> Ottawa_users at lists.osgeo.org <mailto:Ottawa_users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/ottawa_users
> Ask a question on any topic and get answers from real people. *Go to
> Yahoo! Answers.* <http://ca.answers.yahoo.com>
More information about the Ottawa_users
