[Ottawa_users] .qlf format
David Sampson
samper.d at gmail.com
Fri Feb 29 09:44:27 EST 2008
Fantastic info...
>From the info provided by Scott, I am sure that GRASS can manipulate what
you need through v.in.ascii
http://grass.itc.it/grass63/manuals/html63_user/v.in.ascii.html
Check it out...
Cheers
On Fri, Feb 29, 2008 at 8:33 AM, Tweedy, Scott <sctweedy at nrcan.gc.ca> wrote:
> I've been using the FME QLF reader for a while. It works really well.
> However since QLF is really just a glorified text file with the
> following format. An comma-delimited attribute definition line, a line
> defining the number of points in a feature, then the point coordinates.
> That's it. Below is a "dummy" QLF file. I'm sure many of the open
> source readers can be configured to read/write this format.
> xxx,,,,,1,,,,,,,,"XXXXX",,,
> 21
> 363697.000 5110248.000
> 363713.000 5110244.000
> 363722.000 5110259.000
> yyy,,,,,1,,,,,,,,"YYYYY",,,
> 30
> 363136.000 5110242.000
> 363173.000 5110231.000
> 363214.000 5110209.000
> 363280.000 5110147.000
> And so on.
> -----Original Message-----
> From: ottawa_users-bounces at lists.osgeo.org
> [mailto:ottawa_users-bounces at lists.osgeo.org] On Behalf Of jared
> cunningham
> Sent: Thursday, February 28, 2008 19:53
> To: ottawa_users at lists.osgeo.org
> Subject: [Ottawa_users] .qlf format
> Hi,
> Has anyone worked with .qlf format before? Curious if there are any
> conversion tools available without going to FME / ArcGIS Data
> Interoperability?
> Thanks,
> Jared.
> _________________________________________________________________
> Ottawa_users mailing list
> Ottawa_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/ottawa_users
URL: http://lists.osgeo.org/pipermail/ottawa_users/attachments/20080229/f14ee24b/attachment.html
More information about the Ottawa_users
