[owslib-devel] wps branch available
Dominic Lowe dominic.lowe at stfc.ac.uk
Thu Nov 10 03:27:23 PST 2011
Yes, it's our server that show's the wrong namespace - it was initially
developed quite a while ago now and it is probably not fully compliant in
other ways (I can't recall offhand if WPS was even finalised when we
developed it).
I like Jorge's idea of looking for any WPS namespace.
Regards,
Dom
On 10 November 2011 10:11, <jmdj at pml.ac.uk> wrote:
>  Hi to all
> The namespace "http://www.openspatial.net/wps" is an old namespace and
> has been dropped (if you look at the WPS1.0.0 document you have it in
> the SOAP example in page 69).
> In the OGC world the schema structure takes precedence over
> documentation, meaning if it is in the schema then is an "absolute
> truth", and the WPS using that namespace should be updated.
> Luca, maybe you should use an "open mind" approach, using what ever
> namespace is assigned to wps. See the example below on how to get the
> namespace:
> import urllib, stringIO
> from lxml import etree
> xmlIO=urllib.read("
> http://schemas.opengis.net/wps/1.0.0/examples/53_wpsExecute_request_ComplexValue.xml
> wpsXML=etree.parse(xmlIO)
> wpsXML.getroot().nsmap["wps"]
> >>'http://www.opengis.net/wps/1.0.0'
> Jorge
> On 09/11/11 20:56, Cinquini, Luca (3880) wrote:
> > Hi Dom,
> >       thanks for the additional example... I noticed that your service
> uses the namespace "http://www.opengeospatial.net/wps", while the other
> two WPS services I have tested against use "
> http://www.opengis.net/wps/1.0.0".
> > >From the OGC web site it looks like the second namespace should be the
> correct one (see for example:
> http://schemas.opengis.net/wps/1.0.0/wpsGetCapabilities_request.xsd),
> > but maybe I am wrong and we need to support both ? Would you know what
> is the correct way to go ?
> > thanks, Luca
> > On Nov 9, 2011, at 6:56 AM, Dominic Lowe wrote:
> >> Luca,
> >> Many thanks for your contributions.
> >> We also have a WPS server (implemented in Python) that you could test
> >> against:
> http://ceda-wps2.badc.rl.ac.uk/wps?Service=WPS&Request=GetCapabilities&Format=text/xml
> >> The following "DoubleIt" process can be called without security
> >> (DescribeProcess):
> http://ceda-wps2.badc.rl.ac.uk/wps?Service=WPS&Request=DescribeProcess&Version=1.0.0&Identifier=DoubleIt
> >> Regards,
> >> Dom
> >> On 08/11/11 23:10, Luca.Cinquini at jpl.nasa.gov wrote:
> >>> Hi Jorge,
> >>>     these are great examples... if you give me one day (at most two) I
> will expand the code to support them, and provide some tests and
> examples... I'll let you know when you can start giving it a try...
> >>> thanks, Luca
> >>> On Nov 8, 2011, at 3:18 AM, Jorge de Jesus wrote:
> >>>> Ciao Luca
> >>>> Excellent job, we should all buy you some beer :)
> >>>> It's really nice that you are using the USGS WPS since it is  a
> 52North
> >>>> WPS instance, the owslib should be tested against the major WPS
> >>>> implementations (Zoo, degree etc), maybe you could make an
> introduction
> >>>> of owslib in other mailing list and get their support.
> >>>> Anyway if you need you can use the PML WPS instances (vector and
> raster
> >>>> instances are mainly WPS-Grass-Bridge processes)
> >>>> Support page:
> >>>> http://rsg.pml.ac.uk/wps/index.html
> >>>> Test data page:
> >>>> http://rsg.pml.ac.uk/wps/testdata/index.html
> >>>> Examples:
> http://rsg.pml.ac.uk/wps/generic.cgi?request=Execute&service=wps&version=1.0.0&identifier=reprojectImage&datainputs=[inputImage=http://rsg.pml.ac.uk/wps/testdata/elev_srtm_30m.img;outputSRS=EPSG:4326]&responsedocument=outputImage=@asreference=true
> http://rsg.pml.ac.uk/wps/generic.cgi?request=Execute&service=WPS&version=1.0.0&identifier=reprojectCoords&datainputs=[coords=http://rsg.pml.ac.uk/wps/testdata/coords.txt;outputSRS=EPSG:32630;inputSRS=EPSG:4326]
> http://rsg.pml.ac.uk/wps/vector.cgi?request=execute&service=WPS&version=1.0.0&identifier=v.net.path&datainputs=[input=http://rsg.pml.ac.uk/wps/example/graph.gml;file=1%20-960123.1421801624%204665723.56559387%20-101288.65106088226%205108200.011823481]
> >>>> I'll give a look at the code and test it
> >>>> Jorge
> >>>> On 07/11/11 14:42, Cinquini, Luca (3880) wrote:
> >>>>> Hi all,
> >>>>>   I have created a wps branch of owslib that contains a first draft
> support for WPS.
> >>>>> The branch is available here:
> https://owslib.svn.sourceforge.net/svnroot/owslib/branches/wps
> >>>>> The module has been tested against the USGS WPS service - does
> anybody know of another service to test against ?
> >>>>> A good starting point to test functionality is the file
> README_WPS.txt
> >>>>> All WPS functionality is included in separate files, except for a
> small addition to util.py to set the 'text/xml' header for a POST request.
> >>>>> All feedback appreciated,
> >>>>> thanks, Luca
> >>>>> RSA(R) Conference 2012
> >>>>> Save $700 by Nov 18
> >>>>> Register now
> >>>>> http://p.sf.net/sfu/rsa-sfdev2dev1
> >>>>> _______________________________________________
> >>>>> owslib-devel mailing list
> >>>>> owslib-devel at lists.sourceforge.net
> >>>>> https://lists.sourceforge.net/lists/listinfo/owslib-devel
> >>>> Plymouth Marine Laboratory
> >>>> Registered Office:
> >>>> Prospect Place
> >>>> The Hoe
> >>>> Plymouth  PL1 3DH
> >>>> Website: www.pml.ac.uk
> >>>> Click here for PML Annual Review
> >>>> Registered Charity No. 1091222
> >>>> PML is a company limited by guarantee
> >>>> registered in England&  Wales
> >>>> company number 4178503
> >>>> Please think before you print
> >>>> This e-mail, its content and any file attachments are confidential.
> >>>> If you have received this e-mail in error please do not copy,
> disclose it to any third party or use the contents or attachments in any
> way. Please notify the sender by replying to this e-mail or e-mail
> forinfo at pml.ac.uk and then delete the email without making any copies or
> using it in any other way.
> >>>> The content of this message may contain personal views which are not
> the views of Plymouth Marine Laboratory unless specifically stated.
> >>>> You are reminded that e-mail communications are not secure and may
> contain viruses. Plymouth Marine Laboratory accepts no liability for any
> loss or damage which may be caused by viruses.
> >>>> <0x595FF9D3.asc>
> >>> Save $700 by Nov 18
> >>> Register now
> >> Scanned by iCritical.
> >> Save $700 by Nov 18
> >> Register now
> > Save $700 by Nov 18
> > Register now
> Registered Office:
> Prospect Place
> The Hoe
> Plymouth  PL1 3DH
> registered in England & Wales
> If you have received this e-mail in error please do not copy, disclose it
> to any third party or use the contents or attachments in any way. Please
> notify the sender by replying to this e-mail or e-mail forinfo at pml.ac.ukand then delete the email without making any copies or using it in any
> other way.
> The content of this message may contain personal views which are not the
> You are reminded that e-mail communications are not secure and may contain
> viruses. Plymouth Marine Laboratory accepts no liability for any loss or
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20111110/1c890b18/attachment.html>
More information about the OWSLib-devel mailing list
