[owslib-devel] tests intro
Dominic Lowe dominic.lowe at stfc.ac.uk
Mon Apr 2 06:49:30 PDT 2012
Hi Jachym
I use:
python runalldoctests.py
and for a single test:
python runalldoctests.py -t wms_JPLCapabilities.txt
But you're right, most of them fail now due to reliance on old services.
Cheers
Dom
On 31/03/12 22:01, jachym.cepicky at gmail.com wrote:
> Hi,
> could anybody give me short intro about how the tests in owslib are
> structured and how they should be used?
> I have tried:
> cd  tests
> sh rundoctests.dist
> And ended up with 16 errors.
> Any way, how to run each test separately, than in a batch?
> And: My experience shows, that using URLs in service testing is
> dangerous and leads often to non working tests. The tests should IMHO
> not be about testing, weather some service is alive (what is actually
> tested), but parsing capabilities of returned XML (what we need to test).
> Proposal: instead of testing URLs, each test should be constructed, so
> it loads file stored at the harddrive and then it will be parsed. In
> this way, we are also more flexible in test constructions, because we
> can add certain elements to XML files according to what needs to be
> tested "by hand" and we would not be dependent on external services.
> I have a feeling, that at least dozen of my fails are caused by that the
> http://ndg3beta.badc.rl.ac.uk/cows/demo_hadcm3/wfs? is no longer available.
> Any opinion?
> Jachym
Scanned by iCritical.
More information about the OWSLib-devel mailing list
