[owslib-devel] tests intro
Dominic Lowe dominic.lowe at stfc.ac.uk
Mon Apr 2 06:55:20 PDT 2012
And yes your proposal to reduce the use of live URLs sounds good, except how do you test operations that don't return XML, such as getMap, getCoverage etc?
On 02/04/12 14:49, dominic.lowe at stfc.ac.uk wrote:
> Hi Jachym
> I use:
> python runalldoctests.py
> and for a single test:
> python runalldoctests.py -t wms_JPLCapabilities.txt
> But you're right, most of them fail now due to reliance on old services.
> Cheers
> Dom
> On 31/03/12 22:01, jachym.cepicky at gmail.com wrote:
>> Hi,
>> could anybody give me short intro about how the tests in owslib are
>> structured and how they should be used?
>> I have tried:
>> cd  tests
>> sh rundoctests.dist
>> And ended up with 16 errors.
>> Any way, how to run each test separately, than in a batch?
>> And: My experience shows, that using URLs in service testing is
>> dangerous and leads often to non working tests. The tests should IMHO
>> not be about testing, weather some service is alive (what is actually
>> tested), but parsing capabilities of returned XML (what we need to test).
>> Proposal: instead of testing URLs, each test should be constructed, so
>> it loads file stored at the harddrive and then it will be parsed. In
>> this way, we are also more flexible in test constructions, because we
>> can add certain elements to XML files according to what needs to be
>> tested "by hand" and we would not be dependent on external services.
>> I have a feeling, that at least dozen of my fails are caused by that the
>> http://ndg3beta.badc.rl.ac.uk/cows/demo_hadcm3/wfs? is no longer available.
>> Any opinion?
>> Jachym
Scanned by iCritical.
More information about the OWSLib-devel mailing list
