[owslib-devel] how does filter work
Tom Kralidis tomkralidis at hotmail.com
Mon Apr 16 15:45:46 PDT 2012
Hi Jachym: thanks for the info.  owslib/fes.py is used for 1./ parsing FilterCapabilities XML and 2./ creating a filter statement.  owslib/fes.py does not perform actual filtering.  This is primarily used by owslib/csw.py.  Having said this, owslib/feature/wfs*.py _could_ use owslib/fes.py to generate a filter statement as part of the getfeature filter parameter.
..Tom
Date: Mon, 16 Apr 2012 00:38:05 +0200
To: owslib-devel at lists.sourceforge.net
Subject: [owslib-devel] how does filter work
I'm working on the WFS-client issues (approaching!), and I would have
one question:
	can I use (and if so, then how) owslib's filter to be applied on
local-stored (e.g.) GML file? Or is that just intended to be used with
WFS client (filter paramter of the getfeature method) ?
Thanks
Jachym
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
jachym.cepicky at gmail.com | jachym at hsrs.cz
http://les-ejk.cz | http://bnhelp.cz
For Developers, A Lot Can Happen In A Second.
Boundary is the first to Know...and Tell You.
Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
http://p.sf.net/sfu/Boundary-d2dvs2
owslib-devel mailing list
https://lists.sourceforge.net/lists/listinfo/owslib-devel
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20120416/e058d34a/attachment.html>
More information about the OWSLib-devel mailing list
