[owslib-devel] wfs110 patch applied
Jachym Cepicky
jachym.cepicky at gmail.com
Sun Apr 29 13:46:36 PDT 2012
finally, after testing all the servers I'm usually supposed, to be
testing against with (not MapServer, ArcIMS), I've submitted the patch.
In short again: two files were modified
crs.py - more verbose CRS parser, new "encoding" attribute, so the CRS
object is aware of how it was created
wfs110.py - several parser fixes (namespaces issue), getfeature accepts
now bbox parameter with axis in *x,y* order. propetyname parameter will
be omitted, if it will not be specified - there were issues with
mapserver and arcims, they are both handling it correctly, if there is
"nothing", rather then empty string or "*"
I hope, everything is fine for you - let me know in case, you would
found, any troubles.
Thanks
Jachym
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
jachym.cepicky at gmail.com | jachym at hsrs.cz
http://les-ejk.cz | http://bnhelp.cz
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20120429/8a8697cd/attachment.pgp>
More information about the OWSLib-devel
