[owslib-devel] WPS branch
Tom Kralidis tomkralidis at hotmail.com
Sun Jun 3 14:58:05 PDT 2012
Luca: great work -- thanks very much for this!  Some comments:
- can you put what you can from README_WPS.txt in owslib/wps.py (i.e. as docstring comments, etc.), or even better add these as documentation to docs/en/index.rst?
- can you merge owslib/wps_utils.py into owslib/util.py, assuming you can't use what's already in owslib/util.py (e.g. util.testXMLValue might do the same thing as wps_utils.parseText)?
Having said this, we should get this into trunk sooner than later, so I'm okay with Luca committing this to trunk given the above is considered.
Thanks
..Tom
> From: Luca.Cinquini at jpl.nasa.gov
> To: jachym.cepicky at gmail.com
> Date: Sun, 3 Jun 2012 19:38:25 +0000
> CC: owslib-devel at lists.sourceforge.net; pywps-devel at wald.intevation.org
> Subject: Re: [owslib-devel] WPS branch
> Hi Jachym,
> 	thanks, I appreciate the extra work on a Sunday...
> best regards,
> Luca
> On Jun 3, 2012, at 12:22 PM, Jachym Cepicky wrote:
> > hi,
> > thanks for submitting
> > I've tested it (up to describe-process phase ;-) )  on one of our PyWPS
> > deployments (http://apps.esdi-humboldt.cz/pywps/), it worked perfectly.
> > I like the way, the client is implemented - nice work, thanks!
> > Jachym
> > Dne 3.6.2012 13:14, Cinquini, Luca (3880) napsal(a):
> >> Hi all,
> >> 	I believe the WPS branch is ready for some independent testing...
> >> I merged the latest trunk into the branch. The code seems to be working well with invocations to the USGS and PML WPS services, at least the examples I tried.
> >> Good starting points for trying out the code are:
> >> o The README_WPS.txt file
> >> o The wps* examples in the examples/ directory
> >> o The wps*.txt tests in the tests/ directory
> >> o The wps-client.py program in the examples/ directory
> >> All feedback is appreciated,
> >> thanks, Luca
> >> Live Security Virtual Conference
> >> Exclusive live event will cover all the ways today's security and
> >> threat landscape has changed and how IT managers can respond. Discussions
> >> will include endpoint security, mobile security and the latest in malware
> >> threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> >> _______________________________________________
> >> owslib-devel mailing list
> >> https://lists.sourceforge.net/lists/listinfo/owslib-devel
> > Jachym Cepicky
> > Help Service - Remote Sensing s.r.o.
> > jachym.cepicky at gmail.com | jachym at hsrs.cz
> > http://les-ejk.cz | http://bnhelp.cz
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20120603/44b3b2bb/attachment.html>
More information about the OWSLib-devel mailing list
