[owslib-devel] owslib fork on github
Kyle Wilcox
KWilcox at asascience.com
Mon Jun 11 14:38:26 PDT 2012
I agree, this is getting out of control quickly.
Can you grant me commit access to the kyle-github branch and I will get all of the tests passing? It is at a good place for integration
> -----Original Message-----
> From: Jachym Cepicky [mailto:jachym.cepicky at gmail.com]
> Sent: Monday, June 11, 2012 4:18 PM
> To: Cinquini, Luca (3880)
> Cc: Kyle Wilcox; Tom Kralidis; owslib-devel at lists.sourceforge.net; Sean
> Cowan; derrick.snowden at noaa.gov
> Subject: Re: [owslib-devel] owslib fork on github
> Kyle,
> I'm glad, the tests are working and your work is approaching well, but if you
> will continue with the development any further, we will never be able to
> merge your useful changes back to SVN. Even I like GIT as well and see it's
> advantages over SVN, please accept, that SVN is *the* repository, where
> changes are made and GIT is only mirrored. If you want your patches to be
> submitted, please work on the svn-created branch.
> Once you (we all) consider it "done", we can move the changes between svn
> branches easy.
> There was already proposal to move the main source code tree to GIT and I
> think, once some finished release is out, nobody will be against it.
> Till than, could you please merge your last changes back to the created svn-
> branch, so we can evaluate the changes and put them to trunk?
> Thanks a lot for your work!
> Jachym
> P.S. There might be different way, how to track changes between two version
> systems (svn and git in this case). But I do not know any other, beside of
> making diffs manually in one (assuming, it is synchronized regular with the
> trunk branch (or master)) and applying them - again manually to the other
> system. This really takes all the advantage of distributed source code
> management out. Not speaking about fun. So if anybody is aware about some
> automatic way how to track those changes, please speak.
> Dne 11.6.2012 22:09, Cinquini, Luca (3880) napsal(a):
> > Hi Kyle,
> > On Jun 11, 2012, at 2:00 PM, Kyle Wilcox wrote:
> >> Thanks Jachym
> >> I just updated my 'trunk' branch on GitHub to be based on the most
> >> recent SVN trunk (r1882)
> >> Some of the commits to trunk in the past few days caused testing
> >> errors so changes (additional commits) were needed
> >> I also updated the WPS tests to go along with Tom's change to avoid parsing
> a WPS's GetCaps on init.
> > I actually had already updated the WPS tests in SVN trunk for the same
> reason - it is likely to give you conflicts when merging, juts be aware...
> > thanks, Luca
> >> https://github.com/kwilcox/owslib/tree/trunk
> >> 66/66 tests passing, /me is cheering
> >>> Sent: Sunday, June 10, 2012 3:45 PM
> >>> To: Tom Kralidis
> >>> Cc: Kyle Wilcox; dominic.lowe at stfc.ac.uk; owslib-
> >>> devel at lists.sourceforge.net; derrick.snowden at noaa.gov; Sean Cowan
> >>> Hi Tom and Kyle,
> >>> one more commit, more stuff should be there, please check r1881
> >>> Hope, it looks well now
> >>> Jachym
> >>> Dne 8.6.2012 22:34, Tom Kralidis napsal(a):
> >>>> Kyle: Jachym applied this patch in an svn branch
> >>> (https://owslib.svn.sourceforge.net/svnroot/owslib/branches/kyle-git
> >>> hub/), but it appears that some files did not get through/got
> >>> deleted/got added.
> >>>> Anyone know of other ways to successfully apply a git patch from
> >>>> github to
> >>> svn?
> >>>> Kyle's fork provides some much needed test fixes and SensorML/SOS
> >>> additions, and overall cleanup, so any advice here would be appreciated.
> >>>> Thanks
> >>>> ..Tom
> >>>> From: KWilcox at asascience.com
> >>>> To: tomkralidis at hotmail.com; jachym.cepicky at gmail.com
> >>>> CC: dominic.lowe at stfc.ac.uk; owslib-devel at lists.sourceforge.net;
> >>>> derrick.snowden at noaa.gov; SCowan at asascience.com
> >>>> Date: Wed, 6 Jun 2012 17:53:42 -0400
> >>>> Subject: RE: [owslib-devel] owslib fork on github
> >>>> I’ve branched my code from master so it might be easier to
> >>>> integrate into SVN. Here are the
> >>>> commits:https://github.com/kwilcox/owslib/commits/trunk And the
> >>>> diff from the current SVN trunk (r1873) is here:
> >>>> https://github.com/downloads/kwilcox/owslib/diff From: Tom
> >>>> Kralidis [mailto:tomkralidis at hotmail.com]
> >>>> Sent: Wednesday, June 06, 2012 8:02 AM
> >>>> To: jachym.cepicky at gmail.com
> >>>> owslib-devel at lists.sourceforge.net; derrick.snowden at noaa.gov; Sean
> >>>> Cowan
> >>>> Jachym: agreed, although I've had my share of issues with git diffs in svn.
> >>>> Kyle: can you provide a diff based on current git master?
> >>>> Thanks
> >>>> ..Tom
> >>>>> Date: Tue, 5 Jun 2012 20:32:37 +0200
> >>>>> From: jachym.cepicky at gmail.com
> >>>>> CC: kwilcox at asascience.com; dominic.lowe at stfc.ac.uk;
> >>>>> scowan at asascience.com
> >>>>> diff ?
> >>>>> J
> >>>>> Dne 5.6.2012 18:07, Tom Kralidis napsal(a):
> >>>>>> Kyle: thanks for this valuable contribution.
> >>>>>> Since the root codebase is on SVN, does anyone know how we can
> >>>>>> make
> >>> this into an SVN patch against which to review?
> >>>>>> ..Tom
> >>>>>>> To: dominic.lowe at stfc.ac.uk
> >>>>>>> Date: Tue, 22 May 2012 11:23:39 -0400
> >>>>>>> CC: owslib-devel at lists.sourceforge.net;
> >>>>>>> Derrick.Snowden at noaa.gov; SCowan at asascience.com
> >>>>>>> Tom pointed us at the two SOS branches in SVN and we reused what
> >>> code was relevant. The SOS support follows the same design pattern
> >>> as the other OWS services and should look familiar to the developers.
> >>>>>>>> From: Dominic Lowe [mailto:dominic.lowe at stfc.ac.uk]
> >>>>>>>> Sent: Tuesday, May 22, 2012 10:16 AM
> >>>>>>>> To: Kyle Wilcox
> >>>>>>>> Cc: owslib-devel at lists.sourceforge.net;
> >>>>>>>> Derrick.Snowden at noaa.gov; Sean Cowan
> >>>>>>>> Hi,
> >>>>>>>> This is great, it would be good to get this merged into the trunk.
> >>>>>>>> Tom, didn't you start work on SOS support a while back?
> >>>>>>>> Is this a completely new implementation or does it use some of
> >>>>>>>> the old SOS code (which was in a branch).
> >>>>>>>> Either way, I think it would be great to add SOS support to
> >>>>>>>> OWSLib. And cleaning up the tests is a big favour...
> >>>>>>>> Cheers,
> >>>>>>>> Dom
> >>>>>>>> On 18/05/12 16:42, KWilcox at asascience.com wrote:
> >>>>>>>>> Hello all -
> >>>>>>>>> Thanks to funding from the NOAA IOOS Program we have been
> able
> >>> to
> >>>>>>>>> do some work on owslib here: https://github.com/kwilcox/owslib
> >>>>>>>>> Some things that are on the fork:
> >>>>>>>>> 1.) Cleaned up the tests and made sure they are all passing
> >>>>>>>>> 2.) Using py.test for the test runner
> >>>>>>>>> 3.) Organized the tests and testing resources
> >>>>>>>>> 4.) Support for SOS 1.0
> >>>>>>>>> GetCapabilities/DescribeSensor/GetObservation
> >>>>>>>>> Some things that are planned in the next few weeks:
> >>>>>>>>> 5.) Support for SOS 2.0
> >>>>>>>>> 6.) Normalize the namespace lookup library wide
> >>>>>>>>> 7.) Abstract all of the GetCapabilitiesReader classes into a
> >>>>>>>>> parent class (WMSCapabilitiesReader, WFSCapabilitiesReader x
> >>>>>>>>> 3, WCSCapabilitiesReader, SosCapabilitiesReader)
> >>>>>>>>> We would like to eventually get this merged into trunk for
> >>>>>>>>> everyone to
> >>>>>>>> enjoy, comments or suggestions are welcome, thanks!
> >>>>>>>>> Live Security Virtual Conference Exclusive live event will
> >>>>>>>>> cover all the ways today's security and threat landscape has
> >>>>>>>>> changed and how IT managers can respond.
> >>>>>>>>> Discussions will include endpoint security, mobile security
> >>>>>>>>> and the latest in malware threats.
> http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> >>>>>>>>> _______________________________________________
> >>>>>>>>> owslib-devel mailing list
> >>>>>>>>> https://lists.sourceforge.net/lists/listinfo/owslib-devel
> >>>>>>>> Scanned by iCritical.
> >>>>>>> Live Security Virtual Conference Exclusive live event will cover
> >>>>>>> all the ways today's security and threat landscape has changed
> >>>>>>> Discussions will include endpoint security, mobile security and
> >>>>>> Exclusive live event will cover all the ways today's security and
> >>>>>> threat landscape has changed and how IT managers can respond.
> >>>>> Jachym Cepicky
> >>>>> Help Service - Remote Sensing s.r.o.
> >>>>> jachym.cepicky at gmail.com | jachym at hsrs.cz http://les-ejk.cz |
> >>>>> http://bnhelp.cz
> >>> Jachym Cepicky
> >>> http://bnhelp.cz
> >> Discussions will include endpoint security, mobile security and the
> Jachym Cepicky
> http://bnhelp.cz
More information about the OWSLib-devel
