[owslib-devel] owslib fork on github
Tom Kralidis
tomkralidis at hotmail.com
Mon Jun 11 16:26:57 PDT 2012
Kyle: I will email you offlist for svn commit access.
Thanks for everyone's understanding here. There appear to be an increasing number of github integration opportunities, so we should revisit moving to github and establish a timeline to make a clean switch.
..Tom
> From: KWilcox at asascience.com
> To: jachym.cepicky at gmail.com; Luca.Cinquini at jpl.nasa.gov
> CC: tomkralidis at hotmail.com; owslib-devel at lists.sourceforge.net; SCowan at asascience.com; derrick.snowden at noaa.gov
> Date: Mon, 11 Jun 2012 17:38:26 -0400
> Subject: RE: [owslib-devel] owslib fork on github
> I agree, this is getting out of control quickly.
> Can you grant me commit access to the kyle-github branch and I will get all of the tests passing? It is at a good place for integration
> > -----Original Message-----
> > From: Jachym Cepicky [mailto:jachym.cepicky at gmail.com]
> > Sent: Monday, June 11, 2012 4:18 PM
> > To: Cinquini, Luca (3880)
> > Cc: Kyle Wilcox; Tom Kralidis; owslib-devel at lists.sourceforge.net; Sean
> > Cowan; derrick.snowden at noaa.gov
> > Subject: Re: [owslib-devel] owslib fork on github
> > Kyle,
> > I'm glad, the tests are working and your work is approaching well, but if you
> > will continue with the development any further, we will never be able to
> > merge your useful changes back to SVN. Even I like GIT as well and see it's
> > advantages over SVN, please accept, that SVN is *the* repository, where
> > changes are made and GIT is only mirrored. If you want your patches to be
> > submitted, please work on the svn-created branch.
> > Once you (we all) consider it "done", we can move the changes between svn
> > branches easy.
> > There was already proposal to move the main source code tree to GIT and I
> > think, once some finished release is out, nobody will be against it.
> > Till than, could you please merge your last changes back to the created svn-
> > branch, so we can evaluate the changes and put them to trunk?
> > Thanks a lot for your work!
> > Jachym
> > P.S. There might be different way, how to track changes between two version
> > systems (svn and git in this case). But I do not know any other, beside of
> > making diffs manually in one (assuming, it is synchronized regular with the
> > trunk branch (or master)) and applying them - again manually to the other
> > system. This really takes all the advantage of distributed source code
> > management out. Not speaking about fun. So if anybody is aware about some
> > automatic way how to track those changes, please speak.
> > Dne 11.6.2012 22:09, Cinquini, Luca (3880) napsal(a):
> > > Hi Kyle,
> > > On Jun 11, 2012, at 2:00 PM, Kyle Wilcox wrote:
> > >> Thanks Jachym
> > >> I just updated my 'trunk' branch on GitHub to be based on the most
> > >> recent SVN trunk (r1882)
> > >> Some of the commits to trunk in the past few days caused testing
> > >> errors so changes (additional commits) were needed
> > >> I also updated the WPS tests to go along with Tom's change to avoid parsing
> > a WPS's GetCaps on init.
> > > I actually had already updated the WPS tests in SVN trunk for the same
> > reason - it is likely to give you conflicts when merging, juts be aware...
> > > thanks, Luca
> > >> https://github.com/kwilcox/owslib/tree/trunk
> > >> 66/66 tests passing, /me is cheering
> > >>> Sent: Sunday, June 10, 2012 3:45 PM
> > >>> To: Tom Kralidis
> > >>> Cc: Kyle Wilcox; dominic.lowe at stfc.ac.uk; owslib-
> > >>> devel at lists.sourceforge.net; derrick.snowden at noaa.gov; Sean Cowan
> > >>> Hi Tom and Kyle,
> > >>> one more commit, more stuff should be there, please check r1881
> > >>> Hope, it looks well now
> > >>> Jachym
> > >>> Dne 8.6.2012 22:34, Tom Kralidis napsal(a):
> > >>>> Kyle: Jachym applied this patch in an svn branch
> > >>> (https://owslib.svn.sourceforge.net/svnroot/owslib/branches/kyle-git
> > >>> hub/), but it appears that some files did not get through/got
> > >>> deleted/got added.
> > >>>> Anyone know of other ways to successfully apply a git patch from
> > >>>> github to
> > >>> svn?
> > >>>> Kyle's fork provides some much needed test fixes and SensorML/SOS
> > >>> additions, and overall cleanup, so any advice here would be appreciated.
> > >>>> Thanks
> > >>>> ..Tom
> > >>>> To: tomkralidis at hotmail.com; jachym.cepicky at gmail.com
> > >>>> CC: dominic.lowe at stfc.ac.uk; owslib-devel at lists.sourceforge.net;
> > >>>> derrick.snowden at noaa.gov; SCowan at asascience.com
> > >>>> Date: Wed, 6 Jun 2012 17:53:42 -0400
> > >>>> I’ve branched my code from master so it might be easier to
> > >>>> integrate into SVN. Here are the
> > >>>> commits:https://github.com/kwilcox/owslib/commits/trunk And the
> > >>>> diff from the current SVN trunk (r1873) is here:
> > >>>> https://github.com/downloads/kwilcox/owslib/diff From: Tom
> > >>>> Kralidis [mailto:tomkralidis at hotmail.com]
> > >>>> Sent: Wednesday, June 06, 2012 8:02 AM
> > >>>> owslib-devel at lists.sourceforge.net; derrick.snowden at noaa.gov; Sean
> > >>>> Cowan
> > >>>> Jachym: agreed, although I've had my share of issues with git diffs in svn.
> > >>>> Kyle: can you provide a diff based on current git master?
> > >>>> Thanks
> > >>>> ..Tom
> > >>>>> Date: Tue, 5 Jun 2012 20:32:37 +0200
> > >>>>> From: jachym.cepicky at gmail.com
> > >>>>> CC: kwilcox at asascience.com; dominic.lowe at stfc.ac.uk;
> > >>>>> scowan at asascience.com
> > >>>>> diff ?
> > >>>>> J
> > >>>>> Dne 5.6.2012 18:07, Tom Kralidis napsal(a):
> > >>>>>> Kyle: thanks for this valuable contribution.
> > >>>>>> Since the root codebase is on SVN, does anyone know how we can
> > >>>>>> make
> > >>> this into an SVN patch against which to review?
> > >>>>>> ..Tom
> > >>>>>>> To: dominic.lowe at stfc.ac.uk
> > >>>>>>> Date: Tue, 22 May 2012 11:23:39 -0400
> > >>>>>>> CC: owslib-devel at lists.sourceforge.net;
> > >>>>>>> Derrick.Snowden at noaa.gov; SCowan at asascience.com
> > >>>>>>> Tom pointed us at the two SOS branches in SVN and we reused what
> > >>> code was relevant. The SOS support follows the same design pattern
> > >>> as the other OWS services and should look familiar to the developers.
> > >>>>>>>> From: Dominic Lowe [mailto:dominic.lowe at stfc.ac.uk]
> > >>>>>>>> Sent: Tuesday, May 22, 2012 10:16 AM
> > >>>>>>>> To: Kyle Wilcox
> > >>>>>>>> Cc: owslib-devel at lists.sourceforge.net;
> > >>>>>>>> Derrick.Snowden at noaa.gov; Sean Cowan
> > >>>>>>>> Hi,
> > >>>>>>>> This is great, it would be good to get this merged into the trunk.
> > >>>>>>>> Tom, didn't you start work on SOS support a while back?
> > >>>>>>>> Is this a completely new implementation or does it use some of
> > >>>>>>>> the old SOS code (which was in a branch).
> > >>>>>>>> Either way, I think it would be great to add SOS support to
> > >>>>>>>> OWSLib. And cleaning up the tests is a big favour...
> > >>>>>>>> Cheers,
> > >>>>>>>> Dom
> > >>>>>>>> On 18/05/12 16:42, KWilcox at asascience.com wrote:
> > >>>>>>>>> Hello all -
> > >>>>>>>>> Thanks to funding from the NOAA IOOS Program we have been
> > able
> > >>> to
> > >>>>>>>>> do some work on owslib here: https://github.com/kwilcox/owslib
> > >>>>>>>>> Some things that are on the fork:
> > >>>>>>>>> 1.) Cleaned up the tests and made sure they are all passing
> > >>>>>>>>> 2.) Using py.test for the test runner
> > >>>>>>>>> 3.) Organized the tests and testing resources
> > >>>>>>>>> 4.) Support for SOS 1.0
> > >>>>>>>>> GetCapabilities/DescribeSensor/GetObservation
> > >>>>>>>>> Some things that are planned in the next few weeks:
> > >>>>>>>>> 5.) Support for SOS 2.0
> > >>>>>>>>> 6.) Normalize the namespace lookup library wide
> > >>>>>>>>> 7.) Abstract all of the GetCapabilitiesReader classes into a
> > >>>>>>>>> parent class (WMSCapabilitiesReader, WFSCapabilitiesReader x
> > >>>>>>>>> 3, WCSCapabilitiesReader, SosCapabilitiesReader)
> > >>>>>>>>> We would like to eventually get this merged into trunk for
> > >>>>>>>>> everyone to
> > >>>>>>>> enjoy, comments or suggestions are welcome, thanks!
> > >>>>>>>>> Live Security Virtual Conference Exclusive live event will
> > >>>>>>>>> cover all the ways today's security and threat landscape has
> > >>>>>>>>> changed and how IT managers can respond.
> > >>>>>>>>> Discussions will include endpoint security, mobile security
> > >>>>>>>>> and the latest in malware threats.
> > http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> > >>>>>>>>> _______________________________________________
> > >>>>>>>>> owslib-devel mailing list
> > >>>>>>>>> https://lists.sourceforge.net/lists/listinfo/owslib-devel
> > >>>>>>>> Scanned by iCritical.
> > >>>>>>> Live Security Virtual Conference Exclusive live event will cover
> > >>>>>>> all the ways today's security and threat landscape has changed
> > >>>>>>> Discussions will include endpoint security, mobile security and
> > >>>>>> Exclusive live event will cover all the ways today's security and
> > >>>>>> threat landscape has changed and how IT managers can respond.
> > >>>>> Jachym Cepicky
> > >>>>> Help Service - Remote Sensing s.r.o.
> > >>>>> jachym.cepicky at gmail.com | jachym at hsrs.cz http://les-ejk.cz |
> > >>>>> http://bnhelp.cz
> > >>> Jachym Cepicky
> > >>> http://bnhelp.cz
> > >> Discussions will include endpoint security, mobile security and the
> > Jachym Cepicky
> > http://bnhelp.cz
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20120611/ae0edeba/attachment.html>
More information about the OWSLib-devel
