[owslib-devel] wfs 1.1.0 client implementation
Tom Kralidis tomkralidis at hotmail.com
Wed Mar 21 13:52:50 PDT 2012
Jachym: thanks for the info.  This seems fair enough.  So by default x/y is expected unless srsname is passed, at which point validated against supported srsname's, and then axis order is set by the Crs object.
..Tom
Date: Wed, 21 Mar 2012 00:03:24 +0100
To: owslib-devel@lists.sourceforge.net
Subject: [owslib-devel] wfs 1.1.0 client implementation
Dear all,
as you might already know, WFS 1.1.0 client-side implemntation in
various software packages is my hobby for these days. Now I approached
to owslib and would have some questions/proposals to getfeature method:
1) accept bounding box parameter *always* in
[mineast,minnorth,maxeast,maxnorth] coordinates order
2) always append information about SRS to the BBOX, default is the
default one from capabilities
3) always append srsname to the request, default is the default from
capabilities
4) formulate the request with propper axis order,
examples:
epsg:4326 -> &BBOX=minx,miny,maxx,maxy,epsg:4326&SRSNAME=epsg:4326
urn:ogc:def:crs:EPSG::4326 ->
&BBOX=miny,minx,maxy,maxx,urn:ogc:def:crs:EPSG::4326&SRSNAME=urn:ogc:def:crs:EPSG::4326
Current behaviour:
getfeature() method accepts bbox=[], srsname=String and passes it to the
URL without any check. at least srsname should be checked, if it is
supported (based on capabilites document) or not. User have to be aware
of the form, he hands over SRSNAME parameter ("epsg:4326" versus
"urn:ogc:def:crs:...") and give the "propper" coords order by hand.
Proposed behaviour:
user gives *always* bbox coords in minx,miny,maxx,maxy form
no matter which SRS encoding he uses, owslib checks against capabilities
which form is supported, uses the propper one and if needed, swaps the
coordiantes in the request.
what do you think?
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
jachym.cepicky@gmail.com | jachym@hsrs.cz
http://les-ejk.cz | http://bnhelp.cz
This SF email is sponsosred by:
Try Windows Azure free for 90 days Click Here
http://p.sf.net/sfu/sfd2d-msazure
owslib-devel mailing list
https://lists.sourceforge.net/lists/listinfo/owslib-devel
More information about the OWSLib-devel mailing list
