[owslib-devel] wfs 1.1.0 client implementation
Dominic Lowe
dominic.lowe at stfc.ac.uk
Thu Mar 22 03:02:14 PDT 2012
Hi Tom, Jachym,
My interpretation was that Jachym's proposal is to ALWAYS use minx,
miny, maxx, maxy in the OWSLib api regardless of the order in any CRS
(specified or not specified) - is that correct? And owslib sorts out the
correct ordering 'under the hood'.
It makes sense I think - I suppose my only concern is that OWSLib now
has to understand certain CRSs.
What happens if a user wants to make a request for a CRS that is
understood by the WFS, but not by OWSLib? - this should still be
possible so do we need to provide a mechanism for letting the user
determine axis order in the case where the srs is not known to OWSLib,
but is understood by the user and WFS?
(e.g. a 'switchXY' boolean argument)
Cheers
Dom
It makes sense and saves
On 21/03/12 20:52, tomkralidis at hotmail.com wrote:
> Jachym: thanks for the info. This seems fair enough. So by default x/y is expected unless srsname is passed, at which point validated against supported srsname's, and then axis order is set by the Crs object.
> ..Tom
> Date: Wed, 21 Mar 2012 00:03:24+0100
To: owslib-devel@lists.sourceforge.net
Subject:[owslib-devel] wfs 1.1.0 client implementation
Dear all,
as you might already know, WFS 1.1.0 client-side implemntation in
various software packages is my hobby for these days. Now I approached
to owslib and would have some questions/proposals to getfeature method:
1) accept bounding box parameter*always* in
[mineast,minnorth,maxeast,maxnorth] coordinates order
2) always append information about SRS to the BBOX, default is the
default one from capabilities
3) always append srsname to the request, default is the default from
capabilities
4) formulate the request with propper axis order,
examples:
epsg:4326 ->&BBOX=minx,miny,maxx,maxy,epsg:4326&SRSNAME=epsg:4326
urn:ogc:def:crs:EPSG::4326 ->
&BBOX=miny,minx,maxy,maxx,urn:ogc:def:crs:EPSG::4326&SRSNAME=urn:ogc:def:crs:EPSG::4326
Current behaviour:
getfeature() method accepts bbox=[], srsname=String and passes it to the
URL without any check. at least srsname should be checked, if it is
supported(based on capabilites document) or not. User have to be aware
of the form, he hands over SRSNAME parameter("epsg:4326" versus
"urn:ogc:def:crs:...") and give the"propper" coords order by hand.
Proposed behaviour:
user gives*always* bbox coords in minx,miny,maxx,maxy form
no matter which SRS encoding he uses, owslib checks against capabilities
which form is supported, uses the propper one and if needed, swaps the
coordiantes in the request.
what do you think?
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
jachym.cepicky@gmail.com| jachym@hsrs.cz
http://les-ejk.cz| http://bnhelp.cz
This SF email is sponsosred by:
Try Windows Azure free for 90 days Click Here
http://p.sf.net/sfu/sfd2d-msazure
owslib-devel mailing list
https://lists.sourceforge.net/lists/listinfo/owslib-devel
> owslib-devel at lists.sourceforge.net
Scanned by iCritical.
More information about the OWSLib-devel
