[OWSLib-devel] tests updates and Python 2.6 support
    Seth G
    sethg at geographika.co.uk
    Sat Jul  1 12:16:04 PDT 2017
Hi Tom,
Thanks for all the work!
With regards to Pillow, the latest version (or anything above 4.0.0)
doesn't support Python 2.6 -
http://pillow.readthedocs.io/en/4.2.x/installation.html
I think 3.4.1 is the last version that supports 2.6.
Personally 3.x and 2.7 (for all those arcpy installs) support is fine
with me.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Sat, Jul 1, 2017, at 02:23 AM, Tom Kralidis wrote:
> Hi all: FYI I've made some initial attempts at cleaning up some of the
> test
> failures. Here's the current status:
> - 2.6 tests error out when trying to pip install Pillow for some reason.
> Any
> ideas/help on figuring this one would be great.  Having said this, should
> we
> consider dropping 2.6 support altogether given the continuing move to
> py3k?
> What do folks think?
> - 2.7 yields 8 errors.  Some code fixes, but mostly updates to tests
> given changes in remote services
> - 3.4 yields 13 and 16 errors mostly bound to py3k-isms (order of dicts,
> etc.);
> the differences in the number of errors look to be bound to moving parts
> of
> remote services
> I'll try to fix the remaining tests when I have more time, but if devs
> can
> take a crack at fixing that would be much appreciated.
> It goes without saying that we need to find a more stable suite of test
> services.  Perhaps creating a setup/bundle via Docker is an option
> (Travis-CI
> appears to support Docker environments).  Any ideas?
> Cheers
> ..Tom
> OWSLib-devel mailing list
> OWSLib-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/owslib-devel
More information about the OWSLib-devel
