[OWSLib-devel] tests updates and Python 2.6 support
Tom Kralidis
tomkralidis at gmail.com
Sun Jul 9 19:54:40 PDT 2017
Thanks Seth. On that note I've issued a pull request at [1]
which drops support for Python 2.6.
Thanks
..Tom
[1] https://github.com/geopython/OWSLib/pull/377
On Sat, Jul 1, 2017 at 3:16 PM, Seth G <sethg at geographika.co.uk> wrote:
> Hi Tom,
> Thanks for all the work!
> With regards to Pillow, the latest version (or anything above 4.0.0)
> doesn't support Python 2.6 -
> http://pillow.readthedocs.io/en/4.2.x/installation.html
> I think 3.4.1 is the last version that supports 2.6.
> Personally 3.x and 2.7 (for all those arcpy installs) support is fine
> with me.
> Regards,
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Sat, Jul 1, 2017, at 02:23 AM, Tom Kralidis wrote:
>> Hi all: FYI I've made some initial attempts at cleaning up some of the
>> test
>> failures. Here's the current status:
>> - 2.6 tests error out when trying to pip install Pillow for some reason.
>> Any
>> ideas/help on figuring this one would be great. Having said this, should
>> we
>> consider dropping 2.6 support altogether given the continuing move to
>> py3k?
>> What do folks think?
>> - 2.7 yields 8 errors. Some code fixes, but mostly updates to tests
>> given changes in remote services
>> - 3.4 yields 13 and 16 errors mostly bound to py3k-isms (order of dicts,
>> etc.);
>> the differences in the number of errors look to be bound to moving parts
>> of
>> remote services
>> I'll try to fix the remaining tests when I have more time, but if devs
>> can
>> take a crack at fixing that would be much appreciated.
>> It goes without saying that we need to find a more stable suite of test
>> services. Perhaps creating a setup/bundle via Docker is an option
>> (Travis-CI
>> appears to support Docker environments). Any ideas?
>> Cheers
>> ..Tom
>> OWSLib-devel mailing list
>> OWSLib-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/owslib-devel
More information about the OWSLib-devel
