[OWSLib-devel] Force async/sync in WPS execute
Carsten Ehbrecht
ehbrecht at dkrz.de
Mon Jan 22 04:46:12 PST 2018
Hello,
I also would like to have the async/sync switch. I have done this on my fork already:
https://github.com/bird-house/OWSLib/blob/1887376ead09e04c60af2bc615414715c62a3611/owslib/wps.py#L274
It is using a simple async boolean parameter … easier to understand. Choose what ever you find more appropriate.
Would be nice to get this into the OWSLib library.
Cheers,
Carsten
Carsten Ehbrecht
Abteilung Datenmanagement
Deutsches Klimarechenzentrum GmbH (DKRZ)
Bundesstraße 45 a • D-20146 Hamburg • Germany
Phone: +49 40 460094-148
FAX: +49 40 460094-270
Email: ehbrecht at dkrz.de
URL: www.dkrz.de
Geschäftsführer: Prof. Dr. Thomas Ludwig
Sitz der Gesellschaft: Hamburg
Amtsgericht Hamburg HRB 39784
> On 22. Jan 2018, at 06:25, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> the change seems reasonable, I think, it's worth the pull request
> J
> ne 21. 1. 2018 v 22:01 odesílatel Adam Laža <ad.laza32 at gmail.com> napsal:
> Hi devs,
> currently I am working on an extension to PyWPS project using OWSLib. I need to send an execute request to a server but in sync mode. However in code [1] attributes 'status' and 'storeExecute', which - at least in case of PyWPS - determine the async/synchronity - are hardcoded to true.
> For my needs I added parameters to WPSExecution.execute() and buildRequest() methods [2]. I'm just wondering if 'status' and 'storeExecute' parameters are hardcoded for any reason? If not, is it desired functionality and my approach to force async/sync mode right?
> Thanks in advance.
> Adam
> [1] https://github.com/geopython/OWSLib/blob/master/owslib/wps.py#L613
> [2] https://github.com/lazaa32/OWSLib/commit/bb94b710c83b48e9f179d29a51f61dffec00475a
> OWSLib-devel mailing list
> OWSLib-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/owslib-devel
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20180122/39092bc0/attachment.bin>
More information about the OWSLib-devel
