[OWSLib-devel] Force async/sync in WPS execute
Adam Laža
ad.laza32 at gmail.com
Sun Jan 28 12:51:47 PST 2018
2018-01-22 13:46 GMT+01:00 Carsten Ehbrecht <ehbrecht at dkrz.de>:
> Hello,
> I also would like to have the async/sync switch. I have done this on my
> fork already:
> https://github.com/bird-house/OWSLib/blob/1887376ead09e04c60af2bc6154147
> 15c62a3611/owslib/wps.py#L274
> It is using a simple async boolean parameter … easier to understand.
> Choose what ever you find more appropriate.
Oh, thanks for the lineage parameter I forgot it in my solution.
I agree that a simple async parameter is easier to understand. I suppose an
use-case when client requests to store status but not to update it, is not
very probable.
> Would be nice to get this into the OWSLib library.
+1
> Cheers,
> Carsten
> Carsten Ehbrecht
> Abteilung Datenmanagement
> Deutsches Klimarechenzentrum GmbH (DKRZ)
> Bundesstraße 45 a • D-20146 Hamburg • Germany
> Phone: +49 40 460094-148
> FAX: +49 40 460094-270
> Email: ehbrecht at dkrz.de
> URL: www.dkrz.de
> Geschäftsführer: Prof. Dr. Thomas Ludwig
> Sitz der Gesellschaft: Hamburg
> Amtsgericht Hamburg HRB 39784
> > On 22. Jan 2018, at 06:25, Jachym Cepicky <jachym.cepicky at gmail.com>
> wrote:
> > Hi,
> > the change seems reasonable, I think, it's worth the pull request
> > J
> > ne 21. 1. 2018 v 22:01 odesílatel Adam Laža <ad.laza32 at gmail.com>
> napsal:
> > Hi devs,
> > currently I am working on an extension to PyWPS project using OWSLib. I
> need to send an execute request to a server but in sync mode. However in
> code [1] attributes 'status' and 'storeExecute', which - at least in case
> of PyWPS - determine the async/synchronity - are hardcoded to true.
> > For my needs I added parameters to WPSExecution.execute() and
> buildRequest() methods [2]. I'm just wondering if 'status' and
> 'storeExecute' parameters are hardcoded for any reason? If not, is it
> desired functionality and my approach to force async/sync mode right?
> > Thanks in advance.
> > Adam
> > [1] https://github.com/geopython/OWSLib/blob/master/owslib/wps.py#L613
> > [2] https://github.com/lazaa32/OWSLib/commit/
> bb94b710c83b48e9f179d29a51f61dffec00475a
> > OWSLib-devel mailing list
> > OWSLib-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/owslib-devel
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20180128/13a8d2bc/attachment.html>
More information about the OWSLib-devel
