[OWSLib-devel] New Release?
Carsten Ehbrecht ehbrecht at dkrz.de
Mon Oct 21 05:38:38 PDT 2024
+1
Carsten
> On 20. Oct 2024, at 12:53, Angelos Tzotsos via OWSLib-devel <owslib-devel at lists.osgeo.org> wrote:
> +1
> Angelos
> On 10/20/24 13:17, Seth G via OWSLib-devel wrote:
>> Hi devs,
>> There have been quite a few fixes and updates to OWSLib in the last few weeks. Would it be a good time to create a new release?
>> Change since the last release are below. How are version numbers decided?
>> The current version is 0.31.0. Most of the changes below are bug fixes, but there are some new features, e.g. OGC Connected Systems API implementation and OAProc: add support for process execution. Should this bump it up to 0.32.0?
>> I'm happy to take care of the release to PyPI (as documented at https://github.com/geopython/OWSLib?tab=readme-ov-file#releasing). My PyPI user account is at https://pypi.org/user/geographika/.
>> * CI: change base URL for GeoNetwork based CSW by @tomkralidis in https://github.com/geopython/OWSLib/pull/926
>> * Add exception handlers for Polygon and Locale methods by @vietnguyengit in https://github.com/geopython/OWSLib/pull/929
>> * remove root loggers (#923) by @tomkralidis in https://github.com/geopython/OWSLib/pull/930
>> * OGC API: capture response headers by @tomkralidis in https://github.com/geopython/OWSLib/pull/931
>> * OGC Connected Systems API by @ChainReaction31 in https://github.com/geopython/OWSLib/pull/928
>> * Fix parsing of options - support missing options by @pduchesne in https://github.com/geopython/OWSLib/pull/939
>> * OAProc: add support for process execution by @tomkralidis in https://github.com/geopython/OWSLib/pull/940
>> * drop Python 3.8/3.9, unpin old dependencies by @tomkralidis in https://github.com/geopython/OWSLib/pull/941
>> * Fix flake8 issues by @kalxas in https://github.com/geopython/OWSLib/pull/943
>> * add stalebot GitHub Action by @tomkralidis in https://github.com/geopython/OWSLib/pull/942
>> * WFS 2.0 URL building by @geographika in https://github.com/geopython/OWSLib/pull/612
>> * changed all 'already exists' errors to warnings by @speleophysics in https://github.com/geopython/OWSLib/pull/769
>> * Lint fixes by @geographika in https://github.com/geopython/OWSLib/pull/948
>> * Add srsname to wfs200.py getfeature GET request by @lpartington in https://github.com/geopython/OWSLib/pull/945
>> * Remove dependency on the Pytz library by @spillner in https://github.com/geopython/OWSLib/pull/949
>> * adds support for gmx:anchor in gmd:identifier by @pvgenuchten in https://github.com/geopython/OWSLib/pull/947
>> * enables gmx:anchor for otherconstraints by @pvgenuchten in https://github.com/geopython/OWSLib/pull/844
>> * Raise an error if GetCapabilities requests don't return XML by @geographika in https://github.com/geopython/OWSLib/pull/861
>> Seth
>> web:https://geographika.net & https://mapserverstudio.net
>> mastodon: @geographika at mastodon.social
>> OWSLib-devel mailing list
>> OWSLib-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/owslib-devel
> Angelos Tzotsos, PhD
> President, Board of Directors
> Open Source Geospatial Foundation
> https://www.osgeo.org/member/angelos-tzotsos/
More information about the OWSLib-devel mailing list
