[OWSLib-devel] New Release?
Tom Kralidis tomkralidis at gmail.com
Tue Oct 22 08:12:06 PDT 2024
Hi Seth: +1 -- thanks for the interest and offer!  Notes:
- our release steps can be found at [1], followed by an email to both
owslib-users and owslib-devel mailing lists
- docs are automatically updated/published on Read the Docs, so no actions
required
- you should already have GitHub privileges to the repository
- I've enabled maintainer privileges for you on PyPI (you should have an
invitation that needs your acceptance/approval)
The general approach over time for OWSLib has been managing minor and
bugfix releases without branching in the 0.x cycle (master branch).  We can
revisit this approach over time if needed.
Having said this, 0.32.0 seems like the right choice for the next release.
Thanks again!
..Tom
[1] https://github.com/geopython/OWSLib?tab=readme-ov-file#releasing
On Mon, Oct 21, 2024 at 8:46 AM Carsten Ehbrecht via OWSLib-devel <
owslib-devel at lists.osgeo.org> wrote:
> +1
> Carsten
> > On 20. Oct 2024, at 12:53, Angelos Tzotsos via OWSLib-devel <
> > +1
> > Angelos
> > On 10/20/24 13:17, Seth G via OWSLib-devel wrote:
> >> Hi devs,
> >> There have been quite a few fixes and updates to OWSLib in the last few
> weeks. Would it be a good time to create a new release?
> >> Change since the last release are below. How are version numbers
> decided?
> >> The current version is 0.31.0. Most of the changes below are bug fixes,
> but there are some new features, e.g. OGC Connected Systems API
> implementation and OAProc: add support for process execution. Should this
> bump it up to 0.32.0?
> >> I'm happy to take care of the release to PyPI (as documented at
> https://github.com/geopython/OWSLib?tab=readme-ov-file#releasing). My
> PyPI user account is at https://pypi.org/user/geographika/.
> >> * CI: change base URL for GeoNetwork based CSW by @tomkralidis in
> https://github.com/geopython/OWSLib/pull/926
> >> * Add exception handlers for Polygon and Locale methods by
> @vietnguyengit in https://github.com/geopython/OWSLib/pull/929
> >> * remove root loggers (#923) by @tomkralidis in
> https://github.com/geopython/OWSLib/pull/930
> >> * OGC API: capture response headers by @tomkralidis in
> https://github.com/geopython/OWSLib/pull/931
> >> * OGC Connected Systems API by @ChainReaction31 in
> https://github.com/geopython/OWSLib/pull/928
> >> * Fix parsing of options - support missing options by @pduchesne in
> https://github.com/geopython/OWSLib/pull/939
> >> * OAProc: add support for process execution by @tomkralidis in
> https://github.com/geopython/OWSLib/pull/940
> >> * drop Python 3.8/3.9, unpin old dependencies by @tomkralidis in
> https://github.com/geopython/OWSLib/pull/941
> >> * Fix flake8 issues by @kalxas in
> https://github.com/geopython/OWSLib/pull/943
> >> * add stalebot GitHub Action by @tomkralidis in
> https://github.com/geopython/OWSLib/pull/942
> >> * WFS 2.0 URL building by @geographika in
> https://github.com/geopython/OWSLib/pull/612
> >> * changed all 'already exists' errors to warnings by @speleophysics in
> https://github.com/geopython/OWSLib/pull/769
> >> * Lint fixes by @geographika in
> https://github.com/geopython/OWSLib/pull/948
> >> * Add srsname to wfs200.py getfeature GET request by @lpartington in
> https://github.com/geopython/OWSLib/pull/945
> >> * Remove dependency on the Pytz library by @spillner in
> https://github.com/geopython/OWSLib/pull/949
> >> * adds support for gmx:anchor in gmd:identifier by @pvgenuchten in
> https://github.com/geopython/OWSLib/pull/947
> >> * enables gmx:anchor for otherconstraints by @pvgenuchten in
> https://github.com/geopython/OWSLib/pull/844
> >> * Raise an error if GetCapabilities requests don't return XML by
> @geographika in https://github.com/geopython/OWSLib/pull/861
> >> Seth
> >> web:https://geographika.net & https://mapserverstudio.net
> >> mastodon: @geographika at mastodon.social
> >> _______________________________________________
> >> OWSLib-devel mailing list
> >> OWSLib-devel at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/owslib-devel
> > Angelos Tzotsos, PhD
> > President, Board of Directors
> > Open Source Geospatial Foundation
> > https://www.osgeo.org/member/angelos-tzotsos/
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20241022/f09a970f/attachment.htm>
More information about the OWSLib-devel mailing list
