[OWSLib-devel] New Release?
Seth G
sethg at geographika.co.uk
Thu Oct 24 06:44:26 PDT 2024
Hi Tom/devs,
OWSLib 0.32.0 is now released. Everything seemed to go smoothly - please let me know if I messed anything up or missed something! I've also now set the current version to '0.33.dev0'.
I was running the test suite locally on Windows and had a few failing tests, I've fixed these and added a new GitHub Action to run the test suite on a Windows runner.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Tue, Oct 22, 2024, at 5:12 PM, Tom Kralidis via OWSLib-devel wrote:
> Hi Seth: +1 -- thanks for the interest and offer! Notes:
> - our release steps can be found at [1], followed by an email to both owslib-users and owslib-devel mailing lists
> - docs are automatically updated/published on Read the Docs, so no actions required
> - you should already have GitHub privileges to the repository
> - I've enabled maintainer privileges for you on PyPI (you should have an invitation that needs your acceptance/approval)
> The general approach over time for OWSLib has been managing minor and bugfix releases without branching in the 0.x cycle (master branch). We can revisit this approach over time if needed.
> Having said this, 0.32.0 seems like the right choice for the next release.
> Thanks again!
> ..Tom
> [1] https://github.com/geopython/OWSLib?tab=readme-ov-file#releasing
> On Mon, Oct 21, 2024 at 8:46 AM Carsten Ehbrecht via OWSLib-devel <owslib-devel at lists.osgeo.org> wrote:
>> +1
>> Carsten
>> > On 20. Oct 2024, at 12:53, Angelos Tzotsos via OWSLib-devel <owslib-devel at lists.osgeo.org> wrote:
>> > +1
>> > Angelos
>> > On 10/20/24 13:17, Seth G via OWSLib-devel wrote:
>> >> Hi devs,
>> >> There have been quite a few fixes and updates to OWSLib in the last few weeks. Would it be a good time to create a new release?
>> >> Change since the last release are below. How are version numbers decided?
>> >> The current version is 0.31.0. Most of the changes below are bug fixes, but there are some new features, e.g. OGC Connected Systems API implementation and OAProc: add support for process execution. Should this bump it up to 0.32.0?
>> >> I'm happy to take care of the release to PyPI (as documented at https://github.com/geopython/OWSLib?tab=readme-ov-file#releasing). My PyPI user account is at https://pypi.org/user/geographika/.
>> >> * CI: change base URL for GeoNetwork based CSW by @tomkralidis in https://github.com/geopython/OWSLib/pull/926
>> >> * Add exception handlers for Polygon and Locale methods by @vietnguyengit in https://github.com/geopython/OWSLib/pull/929
>> >> * remove root loggers (#923) by @tomkralidis in https://github.com/geopython/OWSLib/pull/930
>> >> * OGC API: capture response headers by @tomkralidis in https://github.com/geopython/OWSLib/pull/931
>> >> * OGC Connected Systems API by @ChainReaction31 in https://github.com/geopython/OWSLib/pull/928
>> >> * Fix parsing of options - support missing options by @pduchesne in https://github.com/geopython/OWSLib/pull/939
>> >> * OAProc: add support for process execution by @tomkralidis in https://github.com/geopython/OWSLib/pull/940
>> >> * drop Python 3.8/3.9, unpin old dependencies by @tomkralidis in https://github.com/geopython/OWSLib/pull/941
>> >> * Fix flake8 issues by @kalxas in https://github.com/geopython/OWSLib/pull/943
>> >> * add stalebot GitHub Action by @tomkralidis in https://github.com/geopython/OWSLib/pull/942
>> >> * WFS 2.0 URL building by @geographika in https://github.com/geopython/OWSLib/pull/612
>> >> * changed all 'already exists' errors to warnings by @speleophysics in https://github.com/geopython/OWSLib/pull/769
>> >> * Lint fixes by @geographika in https://github.com/geopython/OWSLib/pull/948
>> >> * Add srsname to wfs200.py getfeature GET request by @lpartington in https://github.com/geopython/OWSLib/pull/945
>> >> * Remove dependency on the Pytz library by @spillner in https://github.com/geopython/OWSLib/pull/949
>> >> * adds support for gmx:anchor in gmd:identifier by @pvgenuchten in https://github.com/geopython/OWSLib/pull/947
>> >> * enables gmx:anchor for otherconstraints by @pvgenuchten in https://github.com/geopython/OWSLib/pull/844
>> >> * Raise an error if GetCapabilities requests don't return XML by @geographika in https://github.com/geopython/OWSLib/pull/861
>> >> Seth
>> >> _______________________________________________
>> >> OWSLib-devel mailing list
>> >> OWSLib-devel at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/owslib-devel
>> > Angelos Tzotsos, PhD
>> > President, Board of Directors
>> > Open Source Geospatial Foundation
>> > https://www.osgeo.org/member/angelos-tzotsos/
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20241024/2080d064/attachment.htm>
More information about the OWSLib-devel
