[OWSLib-users] python package missing ?
Tom Kralidis
tomkralidis at gmail.com
Fri May 20 03:25:03 PDT 2016
Hi Ernest: your packages are fine. The server from which the script is running from cannot see the CSW server. Try to achieve connectivity between the server and the CSW via other means to verify?
Sent from my iPhone
> On May 20, 2016, at 03:33, Ernest Chiarello <ernest.chiarello at univ-fcomte.fr> wrote:
> Hi list,
> i have a problem with a little python script that uses the owslib.
> it works fine on all ubuntu stations, but it fails on my debian server, and i suppose
> a python package is missing, but i do not know which one.
> here is what happens :
> >>> import owslib
> >>> geonetwork = 'http://geonetwork-mshe.univ-fcomte.fr:8080/geonetwork/srv/fre/csw-publication'
> >>> from owslib.csw import CatalogueServiceWeb
> >>> csw = CatalogueServiceWeb(geonetwork, skip_caps=True, username='admin', password='admin')
> >>> csw.transaction(ttype='insert', typename='gmd:MD_Metadata', record=open('Haies_Franche_Comte_metadata.xml').read())
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 432, in transaction
> self._invoke()
> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 635, in _invoke
> self.response = util.http_post(xml_post_url, self.request, self.lang, self.timeout, self.username, self.password)
> File "/usr/lib/python2.7/dist-packages/owslib/util.py", line 372, in http_post
> up = urllib2.urlopen(r,timeout=timeout);
> File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
> return opener.open(url, data, timeout)
> File "/usr/lib/python2.7/urllib2.py", line 431, in open
> response = self._open(req, data)
> File "/usr/lib/python2.7/urllib2.py", line 449, in _open
> '_open', req)
> File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain
> result = func(*args)
> File "/usr/lib/python2.7/urllib2.py", line 1227, in http_open
> return self.do_open(httplib.HTTPConnection, req)
> File "/usr/lib/python2.7/urllib2.py", line 1197, in do_open
> raise URLError(err)
> urllib2.URLError: <urlopen error [Errno -2] Name or service not known>
> here the list of the python packages :
> ii libpython-stdlib:amd64 2.7.9-1 amd64 interactive high-level object-oriented language (default python version)
> ii libpython2.7-minimal:amd64 2.7.9-2 amd64 Minimal subset of the Python language (version 2.7)
> ii libpython2.7-stdlib:amd64 2.7.9-2 amd64 Interactive high-level object-oriented language (standard library, version 2.7)
> ii python 2.7.9-1 amd64 interactive high-level object-oriented language (default version)
> ii python-apt 0.9.3.12 amd64 Python interface to libapt-pkg
> ii python-apt-common 0.9.3.12 all Python interface to libapt-pkg (locales)
> ii python-chardet 2.3.0-1 all universal character encoding detector for Python2
> ii python-dateutil 2.2-2 all powerful extensions to the standard datetime module
> ii python-debian 0.1.27 all Python modules to work with Debian-related data formats
> ii python-debianbts 1.12 all Python interface to Debian's Bug Tracking System
> ii python-defusedxml 0.4.1-2 all XML bomb protection for Python stdlib modules (for Python 2)
> ii python-docutils 0.12+dfsg-1 all text processing system for reStructuredText (implemented in Python 2)
> ii python-egenix-mxdatetime 3.2.8-1 amd64 date and time handling routines for Python
> ii python-egenix-mxtools 3.2.8-1 amd64 collection of additional builtins for Python
> ii python-ldap 2.4.10-1 amd64 LDAP interface module for Python
> ii python-lxml 3.4.0-1 amd64 pythonic binding for the libxml2 and libxslt libraries
> ii python-minimal 2.7.9-1 amd64 minimal subset of the Python language (default version)
> ii python-owslib 0.8.10-1 all Client library for Open Geospatial (OGC) web services
> ii python-pkg-resources 5.5.1-1 all Package Discovery and Resource Access using pkg_resources
> ii python-psycopg2 2.5.4+dfsg-1 amd64 Python module for PostgreSQL
> ii python-reportbug 6.6.3 all Python modules for interacting with bug tracking systems
> ii python-roman 2.0.0-1 all module for generating/analyzing Roman numerals for Python 2
> ii python-six 1.8.0-1 all Python 2 and 3 compatibility library (Python 2 interface)
> ii python-soappy 0.12.22-1 all SOAP Support for Python
> ii python-support 1.0.15 all automated rebuilding support for Python modules
> ii python-tz 2012c+dfsg-0.1 all Python version of the Olson timezone database
> ii python-wstools 0.4.3-2 all WSDL parsing tools Python module
> ii python2.7 2.7.9-2 amd64 Interactive high-level object-oriented language (version 2.7)
> ii python2.7-minimal 2.7.9-2 amd64 Minimal subset of the Python language (version 2.7)
> any idea ?
> Thanks in advance.
> Ernest.
> Ernest CHIARELLO - Ernest.Chiarello at univ-fcomte.fr
> UMR6049 ThéMA -- CNRS / université de Franche-Comté
> 32 rue Mégevand 25030 Besançon cedex
> Tel : 03 81 66 54 80 Mob : 07 82 99 11 08
> OWSLib-users mailing list
> OWSLib-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/owslib-users
More information about the OWSLib-users
