[pal-developer] displayAll
Vianney Dugrain
Vianney.Dugrain at nateko.lu.se
Fri Jul 9 10:00:28 EDT 2010
Hi!
Thank you for your answers, I hope that my numerous questions does not trouble you. I have a last one before the WE:
If the boolean displayAll used as parameter in the function labeller() is set to False, does it mean that labels overlapping with any kind of other item is removed, or only labels which overlap each other?
In my example, the labels overlapping with obstacle layers are displayed, even when the boolean is set to false. Is it normal?
Regards!
Vianney
More information about the pal-developer
