[pdal-commits] [PDAL/PDAL] b21e00: throw exceptions when random iterators are not fou...
GitHub
noreply at github.com
Wed Feb 19 12:03:58 PST 2014
Branch: refs/heads/feature/pcl-block
Home: https://github.com/PDAL/PDAL
Commit: b21e0070be4313456179add2a860c1db2c6d55ba
https://github.com/PDAL/PDAL/commit/b21e0070be4313456179add2a860c1db2c6d55ba
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2014-02-14 (Fri, 14 Feb 2014)
Changed paths:
M include/pdal/filters/Predicate.hpp
M include/pdal/filters/Programmable.hpp
Log Message:
throw exceptions when random iterators are not found for filters.programmable and filters.predicate
Commit: b339a86749bf0df9c9d3b1c4ff9214660aceb08e
https://github.com/PDAL/PDAL/commit/b339a86749bf0df9c9d3b1c4ff9214660aceb08e
Changed paths:
M src/plang/PythonEnvironment.cpp
Log Message:
fix up exception throwing to actually throw useful exceptions
Commit: 9a4b16ac2b8254a02a4ed2d7bcaba0660038464a
https://github.com/PDAL/PDAL/commit/9a4b16ac2b8254a02a4ed2d7bcaba0660038464a
Changed paths:
M test/unit/plang/ProgrammableFilterTest.cpp
Log Message:
use BOOST_CHECK_CLOSE so we can get some output when failures happen
Commit: a89cd410a24aadf43c0e14ab0f8e82ccd85996df
https://github.com/PDAL/PDAL/commit/a89cd410a24aadf43c0e14ab0f8e82ccd85996df
Changed paths:
M src/plang/Invocation.cpp
A test/data/pipeline/create-dimension.xml
Log Message:
beef up error detection in cases where Python array types don't match PDAL dimension types
Commit: 3bf58e9d9a23cd0ded7749e420d48260dda56bfe
https://github.com/PDAL/PDAL/commit/3bf58e9d9a23cd0ded7749e420d48260dda56bfe
Changed paths:
M include/pdal/filters/Mosaic.hpp
M src/filters/Mosaic.cpp
A test/data/pipeline/mosaic.xml
M test/unit/filters/MosaicFilterTest.cpp
Log Message:
make filters.mosaic work more better. Provide an example of a mosaic that creates new dimensions, filters data, and updates one leg of the filters.mosaic with Python
Commit: 76aec79598b88ae29748ee49c423c0238578798c
https://github.com/PDAL/PDAL/commit/76aec79598b88ae29748ee49c423c0238578798c
Changed paths:
A test/data/autzen-utm.las
Log Message:
add missing data
Commit: dbb1f27787a2855d676bb655ff03be5a24dcde7a
https://github.com/PDAL/PDAL/commit/dbb1f27787a2855d676bb655ff03be5a24dcde7a
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-02-19 (Wed, 19 Feb 2014)
Changed paths:
M src/drivers/text/Writer.cpp
Log Message:
resolve #243, missing PCD header
Commit: d9a8b45aeda41d48789bb7cef5753f05b0cbfaf6
https://github.com/PDAL/PDAL/commit/d9a8b45aeda41d48789bb7cef5753f05b0cbfaf6
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #244 from PDAL/issue/243-pcd-writer
Commit: f3a4845537e3824a36a3108b1aeb86b21972ad10
https://github.com/PDAL/PDAL/commit/f3a4845537e3824a36a3108b1aeb86b21972ad10
Changed paths:
M src/StageFactory.cpp
Log Message:
resolve #245, pdal translate recognizes PCD format by extension
Commit: 7b45f87d0d6ce3efca1c51c6d6b0c19f5051c087
https://github.com/PDAL/PDAL/commit/7b45f87d0d6ce3efca1c51c6d6b0c19f5051c087
Changed paths:
Log Message:
Merge pull request #246 from PDAL/issue/245-pdal-translate
Commit: 8f2098ede15093b42850d06aab976acf949f1e17
https://github.com/PDAL/PDAL/commit/8f2098ede15093b42850d06aab976acf949f1e17
Changed paths:
Log Message:
Merge branch 'master' into feature/pcl-block
Compare: https://github.com/PDAL/PDAL/compare/7e4239538c43...8f2098ede150
More information about the pdal-commits
