[pdal-commits] [PDAL/PDAL] 7e4239: Initial implementation of the PCL Filter Block wit...
GitHub
noreply at github.com
Wed Feb 19 12:19:33 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 7e4239538c43eb1a8399cf9dd302994dbf569a68
https://github.com/PDAL/PDAL/commit/7e4239538c43eb1a8399cf9dd302994dbf569a68
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-02-12 (Wed, 12 Feb 2014)
Changed paths:
M CMakeLists.txt
M Vagrantfile
A doc/stages/filters.pclblock.txt
M doc/stages/index.txt
M include/pdal/Drivers.hpp
M include/pdal/Filters.hpp
A include/pdal/PCLConversions.hpp
M include/pdal/PointBuffer.hpp
A include/pdal/filters/PCLBlock.hpp
M pdal_defines.h.in
A scripts/vagrant/pcl.sh
M scripts/vagrant/pdal.sh
M src/CMakeLists.txt
M src/PointBuffer.cpp
M src/StageFactory.cpp
A src/filters/PCLBlock.cpp
A test/data/pipeline/outlier_removal.json
A test/data/pipeline/passthrough.json
A test/data/pipeline/passthrough_outlier_removal.json
A test/data/pipeline/pipeline_pclblock.xml
A test/data/pipeline/pipeline_pclblock_combined.xml
A test/data/pipeline/pipeline_pclblock_outlier_removal.xml
A test/data/pipeline/pipeline_pclblock_passthrough.xml
A test/data/pipeline/pipeline_pclblock_progressive_morphological_filter.xml
A test/data/pipeline/pipeline_pclblock_voxel_grid.xml
A test/data/pipeline/progressive_morphological_filter.json
A test/data/pipeline/voxel_grid.json
M test/unit/CMakeLists.txt
A test/unit/filters/PCLBlockFilterTest.cpp
Log Message:
Initial implementation of the PCL Filter Block with sample pipelines, draft documentation, and representative unit tests. Vagrantfile is updated to also load and build PCL (required).
Commit: 8f2098ede15093b42850d06aab976acf949f1e17
https://github.com/PDAL/PDAL/commit/8f2098ede15093b42850d06aab976acf949f1e17
Date: 2014-02-19 (Wed, 19 Feb 2014)
Changed paths:
M include/pdal/filters/Mosaic.hpp
M include/pdal/filters/Predicate.hpp
M include/pdal/filters/Programmable.hpp
M src/drivers/text/Writer.cpp
M src/filters/Mosaic.cpp
M src/plang/Invocation.cpp
M src/plang/PythonEnvironment.cpp
A test/data/autzen-utm.las
A test/data/pipeline/create-dimension.xml
A test/data/pipeline/mosaic.xml
M test/unit/filters/MosaicFilterTest.cpp
M test/unit/plang/ProgrammableFilterTest.cpp
Log Message:
Merge branch 'master' into feature/pcl-block
Commit: 2c6aa8510071f2e2bc9cb9f0d60fc529b047eba3
https://github.com/PDAL/PDAL/commit/2c6aa8510071f2e2bc9cb9f0d60fc529b047eba3
Author: Howard Butler <howard at hobu.co>
Changed paths:
M CMakeLists.txt
M Vagrantfile
M pdal_defines.h.in
Log Message:
Merge pull request #247 from PDAL/feature/pcl-block
Feature/pcl block
Compare: https://github.com/PDAL/PDAL/compare/7b45f87d0d6c...2c6aa8510071
More information about the pdal-commits
