[pdal-commits] [PDAL/PDAL] b7cde7: Rename all drivers.*.reader to readers.* and
GitHub noreply at github.com
Mon Nov 24 12:32:14 PST 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: b7cde7e1fb13f28db1de7797dbb31392db1f7dfc
      https://github.com/PDAL/PDAL/commit/b7cde7e1fb13f28db1de7797dbb31392db1f7dfc
  Author: Paul Ramsey <pramsey at cleverelephant.ca>
  Date:   2014-11-24 (Mon, 24 Nov 2014)
  Changed paths:
    M doc/apps.rst
    M doc/compilation/dependencies.rst
    M doc/metadata.rst
    M doc/pipeline.rst
    R doc/stages/drivers.nitf.reader.rst
    R doc/stages/drivers.nitf.writer.rst
    R doc/stages/drivers.oci.reader.rst
    R doc/stages/drivers.oci.writer.rst
    R doc/stages/drivers.p2g.writer.rst
    R doc/stages/drivers.pcd.reader.rst
    R doc/stages/drivers.pcd.writer.rst
    R doc/stages/drivers.pclvisualizer.writer.rst
    R doc/stages/drivers.pgpointcloud.reader.rst
    R doc/stages/drivers.pgpointcloud.writer.rst
    R doc/stages/drivers.rxp.reader.rst
    M doc/stages/filters.attribute.rst
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.colorization.rst
    M doc/stages/filters.crop.rst
    M doc/stages/filters.decimation.rst
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/filters.predicate.rst
    M doc/stages/filters.programmable.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/filters.sort.rst
    M doc/stages/index.rst
    M doc/stages/readers.buffer.rst
    M doc/stages/readers.faux.rst
    M doc/stages/readers.las.rst
    A doc/stages/readers.nitf.rst
    A doc/stages/readers.oci.rst
    A doc/stages/readers.pcd.rst
    A doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.qfit.rst
    A doc/stages/readers.rxp.rst
    M doc/stages/readers.sbet.rst
    A doc/stages/writers.nitf.rst
    A doc/stages/writers.oci.rst
    A doc/stages/writers.p2g.rst
    A doc/stages/writers.pcd.rst
    A doc/stages/writers.pclvisualizer.rst
    A doc/stages/writers.pgpointcloud.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_block_tutorial.rst
    M doc/tutorial/reading.rst
    M doc/vagrant.rst
    M plugins/greyhound/drivers/GreyhoundReader.hpp
    M plugins/icebridge/drivers/IcebridgeReader.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/mrsid/drivers/MrsidReader.hpp
    M plugins/nitf/drivers/NitfReader.hpp
    M plugins/nitf/drivers/NitfWriter.hpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/oci/drivers/OciReader.hpp
    M plugins/oci/drivers/OciWriter.hpp
    M plugins/oci/test/OCITest.cpp
    M plugins/p2g/drivers/P2gWriter.hpp
    M plugins/pcl/drivers/PCLVisualizer.hpp
    M plugins/pcl/drivers/PcdReader.hpp
    M plugins/pcl/drivers/PcdWriter.hpp
    M plugins/pcl/kernel/Ground.hpp
    M plugins/pgpointcloud/drivers/PgReader.hpp
    M plugins/pgpointcloud/drivers/PgWriter.cpp
    M plugins/pgpointcloud/drivers/PgWriter.hpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/rxp/drivers/RxpReader.hpp
    M plugins/rxp/test/RxpReaderTest.cpp
    M plugins/sqlite/drivers/SQLiteReader.hpp
    M plugins/sqlite/drivers/SQLiteWriter.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M python/pdal/pipeline_xml.py
    M python/pdal/test.py
    M schemas/8-dimension-schema.xml
    M scripts/vagrant/loadpgpointcloud.xml
    M scripts/vagrant/readpgpointcloud.xml
    M src/StageFactory.cpp
    M src/kernel/Kernel.cpp
    M test/data/bpf/bpf2nitf.xml
    M test/data/drivers/p2g-writer.xml
    M test/data/drivers/sqlite-reader.xml
    M test/data/drivers/sqlite-writer.xml
    M test/data/icebridge/pipeline.xml
    M test/data/nitf/chipper.xml
    M test/data/nitf/conversion.xml
    M test/data/nitf/las2nitf.xml
    M test/data/nitf/reader.xml
    M test/data/nitf/write_laz.xml
    M test/data/nitf/write_options.xml
    M test/data/oracle/big-read.xml
    M test/data/oracle/big-write.xml
    M test/data/oracle/qfit-read.xml
    M test/data/oracle/qfit-write.xml
    M test/data/oracle/read-colorize.xml
    M test/data/oracle/read.xml
    M test/data/oracle/view-read.xml
    M test/data/oracle/write.xml
    M test/data/pipeline/pipeline_interpolate.xml
    M test/data/soci/read-cloud.xml
    M test/data/soci/read.xml
    M test/data/soci/sthelens-write.xml
    M test/data/soci/write-utm.xml
    M test/data/soci/write.xml
    M test/perf/chipper.xml
    M test/perf/chipper_nocache.xml
  Log Message:
rename all drivers.*.writer to writers.*
  Commit: a99437c9043eaaa2bdcc56a604d7c36d35cdccf4
      https://github.com/PDAL/PDAL/commit/a99437c9043eaaa2bdcc56a604d7c36d35cdccf4
  Changed paths:
  Log Message:
  Fix readers/readres typos
  Commit: b1fc7a3f3fd4a89f2b929971552bcb728bf4cab7
      https://github.com/PDAL/PDAL/commit/b1fc7a3f3fd4a89f2b929971552bcb728bf4cab7
  Changed paths:
    M apps/pdal.cpp
  Log Message:
  Fix mistaken touch of kernel names
  Commit: a58d4703d73271476b081be4b435b84559242b9d
      https://github.com/PDAL/PDAL/commit/a58d4703d73271476b081be4b435b84559242b9d
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M apps/pdal.cpp
    M doc/apps.rst
    M doc/metadata.rst
    M doc/pipeline.rst
    M doc/vagrant.rst
  Log Message:
  Merge pull request #629 from pramsey/doc_filter_rename
Rename all drivers.*.reader to readers.* and more
Compare: https://github.com/PDAL/PDAL/compare/47db38c272dd...a58d4703d732
More information about the pdal-commits mailing list
