[pdal-commits] [PDAL/PDAL] 22937f: view kernel need not be built without PCL_VISUALIZ...
GitHub
noreply at github.com
Mon Nov 24 12:48:35 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 22937f65d616e590190229a739d17e42f37bba83
https://github.com/PDAL/PDAL/commit/22937f65d616e590190229a739d17e42f37bba83
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-11-24 (Mon, 24 Nov 2014)
Changed paths:
M plugins/pcl/CMakeLists.txt
M plugins/pcl/kernel/View.cpp
Log Message:
view kernel need not be built without PCL_VISUALIZATION_FOUND, it can also use the visualize method to invoke the visualizer
Commit: 1f99bbe2c2ba74cb978879be59e5dd2c6f7d4aa9
https://github.com/PDAL/PDAL/commit/1f99bbe2c2ba74cb978879be59e5dd2c6f7d4aa9
Changed paths:
M plugins/pcl/kernel/View.hpp
Log Message:
add ability to visualize a range of points in view kernel
Commit: 6879421e7d8cda0a7afcc2f7b991b8a8a970abbb
https://github.com/PDAL/PDAL/commit/6879421e7d8cda0a7afcc2f7b991b8a8a970abbb
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #628 from PDAL/pcl-visualize-tweaks
Compare: https://github.com/PDAL/PDAL/compare/a58d4703d732...6879421e7d8c
More information about the pdal-commits
